  • Replies 1k
Posted Images
Interesting stuff SydneyKid, can the two controllers share a common plug to the h/c?
Or do you have to unplug one and shift the cable to the other when making adjustments?
Just interested becauase I would most likely build them into the same chassis.
Just looking at the circuit diagrams, I would say you can only have one plugged in at once as they use common pins. You may be able to switch the data streams over though, rather than physically unplug the Controller from one and plug it into the other.:D
or get an rs232 switch that you can strip out of its metal box and put into the dash somewhere to allow switching.
sk i have seen flat rs 232 cables we have them hanging off the back of our pcs at work cant figure out what they connect to tho. looks like a ribbon cable with a tiny flat rs232 connector at the end i will try to take a pic
what's the sampling rate of the boost controller?
The data source is one injector, it doesn't matter which one. So the "samples" will be supplied at 1/2 engine rpm, the IC is much faster than that. It will increase as the engine rpm rises, which is coincidentally just what you would want. Perhaps not "coincidentally" maybe the Sillycoon Chump thought about it.:D
everything that you've said so far makes perfect sense. Now, all I;m waiting for before going ahead, is your real world test results to see if the little beauty performs as it's supposed to.
Also, I'll wait to see how many things need to be connected up.
And then next comes the fuel modifyer. hehehe
Cheers Gary
As you can see I have finished building the kits, the boost controller was the last one. It took around 1.5 hours to build. If I get time i will connect them up over the weekend, I will leave the fuel at zero (no correction) until I get time on the dyno. But I might give the boost a tweak straight away. If I do, I will post up the results. Regardless I will do before and after runs on the dyno.
It took me around 3 hours to fully read the instructions and background theory, then build the Fuel Adjuster and calibrate it. Then about 1 hour to build the Controller and about 1.5 hours to build the Boost Controller. All up around 5.5 hours of easy, no rush work. There is a bit of set up (calibration) involved in the Fuel Adjuster. The Controller has no set up, just adjust the display brightness. The Boost Controller has to be set up (calibrated) in the car, but it looks pretty simple.
There are only 8 connections to be made in the car, and the power supplies (+ and - 12 volts) are common, so that's really only 6 connections. I will make them all at the ECU, saves running wires under the bonnet. If someone has access to a good copy of the Stagea ECU pin out, this thread would be a good place to put it up. The connections are;
Fuel Adjuster;
Red = 12 volts +
Black = 12 volts -
Green = input from AFM
Black = output to ECU (where the AFM used to be connected)
Boost Controller;
Red = 12 volts +
Black = 12 volts -
Green = input from injector
Black = output to the standard solenoid
:P
PS; the Jaycar guys asked me to rate the kits when I was in there yesterday. Well I rate them as one of the best kits I have assembled, good instructions with pictures, easy to read, well laid out boards and all required components are included. I am no electronics engineer, and I had no problems. "Highly Recommended" would be my summing up.
Good work SK.
Apparently the Stage (series 1) ECU has the same pin out as the R34 GTT. It certainly has the same plug that's for sure.
Here's a link to the pinouts for the R34 GTT.
http://members.iinet.net.au/~jay77/R34ECUpinouts.pdf
Cheers
J
I though it might be handy if I added the ECU pins I intend to use;
Fuel Adjuster;
Red = 12 volts + * Pin 31
Black = 12 volts - * Pin 32
Green = input from AFM * the cut wire that used to go to Pin 54
Black = output to ECU (where the AFM used to be connected)* Pin 54
Boost Controller;
Green = input from injector * Pin 101 (cylinder #1)
Black = output to the standard solenoid * the cut wire that used to go to Pin 104
I have now fully tested them and the connections are as posted above.:P
Does anyone know if Stageas have peak hold injectors? I am getting erratic signals from #1 injector switching at the ECU, which is usually a sign of peak hold injectors. But I thought all RB25DET injectors were high impedance, usually peak hold uses low impedance injectors. Anyone measured the impedance of Stagea injectors? :)
I remember skylinegeoff telling me that he had to wire in some resistors to his injectors when he replaced them with aftermarket ones so that the injectors worked properly with the signal. He may be able to shed some light on the topic.
Nup. I have some toyota 440cc injectors that are low impedence (3.3 ohm) so I need the resistors to protect the ECU. Daresay it will have little to do with the suspected peak hold facility on the Stag injectors.
Time to throw a big auto multimeter on it SK and sample the injector signal. Oh...and the impedence :P
Maybe time to visit my best friend the electronics engineer, he has a nice scope and the knowledge to use it. I don't want to build a Jaycar peak hold adaptor if I don't have to.:P
PS; I got sick of waiting, so at 4.00 am today I rerouted the vacuum hoses and worked the boost up to 0.5 bar, goes a lot better than 0.3/0.4 bar. Zero cost, 10 minute job.
How, what?? What did you do that cost nothing and only took 10 minutes?
I thought everyone with an RB25DET knew how to do it. You just disconnect the solenoid (vacuum, not electricaly), connect the boost feed directly to the wastegate and use the (standard) restrictor to bypass the desired amount back into the turbo inlet. The standard byspass hole of 1.25 mm bypasses enough air flow for 0.5 bar. Tools needed = one pair of pliers and 10 minutes.:P
PS; If you want more boost you can drill out the bypass, 1.5 mm = more boost (around 0.7 bar) 1.75mm = a bit more (around 1.0 bar). But the Jaycar Boost Controller needs the bypass to relieve trapped pressure between the solenoid and the wastegate actuator. So I don't want to redrill the restrictor only have to solder it back up again.
One thing I've been thinking about. Being an electronic boost controller, what does it use to sence the boost presure ? Does it have it's own map sensor? or does it figure out what it needs to do by going off the duty of the injector that you need to tap into ?
It's also something I need to find out about the Unichip boost control module, does it need a map sensor.. If so I'll have to source a one and install it cause the Stagea's don't have one from factory - no boost gauge..
J
No , not me - I know nothing, and now realise that I know even less... :D
Any links to pics/diagrams that illustrate the bits you refer to? As I said - I know nothing - except how to replace the panel filter! :D I once had a Mk I GT 440 Consul Cortina that I knew what did what and could even fix when minor things went wrong, but now days when I open a bonnet I just go "Hmmm, engine" and that's as far as it gets!
:P
This is the 10 minute no cost boost to 0.5 bar rerouting of the vacuum hoses. Disconnect the two vaccum hoses from the solenoid. Then connect the boost feed (from the cross over pipe on the left of the picture) to a the standard T piece. Connect one side of the T piece directly to the wastegate actuator (on the right of the picture). The remaing connection on the T piece goes back into the inlet via the BOV return pipe (on the standard fitting). Make sure to put the the standard brass restrictor in that vacuum hose to bypass the desired amount back into the turbo inlet. The standard bypass hole of 1.25 mm bypasses enough air flow for 0.5 bar.
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
