For the hypothetical argument:-
For the ignition timing, I think that you would need a dpa to intercept each spark plug. Thats if that is how they work.
That's 6 bulky shithouselooking cream boxes that you would have trouble hiding in the non existent room behind the dash. The idea is good, but I think if you had to buy 6, the cost would be similar to a unichip.
Or maybe I'm looking at it the wrong way, are you saying that you intecept the signal from the CAS? That may work...
Or something else that the ECU uses to calculate the ignition timing.
Unfortunatley, I don't know enough about CAS signals or format. Maybe someone else could enlighten.
The real answer is stop fuggin around and get a PFC.
I think that basicly, if you want to do more than bend the AFM voltage, then a PFC is the way to go as it can give you control over everything. Easy to fit, better tuning results and less ugly plastic boxes to hide.
I do know that they can be used to do a speedo correction.
You might be able to use them to fool the speed limiter.
There is probably a 101 uses for them, all limited by you imagination.
  • Replies 1k
Posted Images
Ok I'm going to have to jump in the middle of your convo here...
Well I thought the IEBC was working for me, but turns out, it doesnt work at all! I cannot make it go higher or lower than 7-8 psi no matter what setting I put in. Anyone know what's going on?
Unfortunately, it ain't that easy - there isn't a PowerFC available that is a direct plug-in to the Stagea wiring loom (this is that Stagea section of the forums, after all).
Getting one to work involves, amongst other things, converting your Stagea to manual (none of the series 1 RB25-engined Stageas were manual, and there are no PFC's for auto Skylines), hacking up the Stagea wiring loom to suit the PowerFC (or vice-versa), and sorting out an alternative method to keep the ATESSA control - most of the Stageas that come into the country are AWD, and there were no RB25DET-engined Skylines that also had the ATESSA system.
The Apexi SITC changes the CAS signal at 5 rpm points, with interpolation between them. So you achieve the timing that you want. This thread covers fitting an SITC to a Stagea;
http://www.skylinesaustralia.com/forums/in...showtopic=80642
:) cheers :rofl:
I'd agree with that. But like SK has pointed out - there are better options for timing.
I guess I overlooked the whole stagea thing as I have a manual skyline...
The fact that SK couldn't put in a PFC is the major reason this thread was started hey!
ive fried two IEBC's by switching too slowly from high to low, kinda staying in between.
It caused heat to build up in one of the resitors and it to burn out. I replaced it but never worked again. The result was the EBC being stuck on load point 64. Basically making it as good as a bleed valve :)
:) cheers :rolleyes:
So you could use a DFA to change the signal from the CAS? and it would probably work better than the SITC as it has more resolution?
Just throwing around a few ideas... At the moment Ive got the DFA and IEBC and a Universal Voltage Switch kit running an intercooler water spray... could add another beige box. ;-)
Hey, I just found out something.
I have a DFA and lately on cold nights, I have been loosing power between 5000rpm and 7000rpm,and going through more fuel.
Plugged in the controller and found that the input was 1 and the output 0. SO I pulled it apart and found the red led wasn't on. The "switch in" was not working. I had to adjust VR4 to get it to switch on when the engine turned over. And now the red light comes on.
So I'm not sure how this happened. Maybe vibrations caused VR4 to unscrew changing the resistance, or maybe it's because I changed batteries and the alernator doesn't charge the battery as vigourously anymore (the old one was fooked). Anyway, just thought I'd share.
Help!!!! I have a standard R33 boost control solonoid and an Apexi 3 port boost control solonoid.
1. Which one will be better to use?
2. Will the Apexi item flow better with more control due to its larger ports?
3. How do you set The 3 port up? Obviously you put the two barbs to COM (in) and NC (out) but what do you do with the NO port?
4. Is there anything else required to change the setup of the solonoid to NC operation fom NO?
Cheers in advance :)
NO = Normally Open
NC = Normally Closed
These are the two states of the outputs when the solenoid is NOT energized.
COM = Common Input
For this application it's best to use a NC, as for the vast majority of the time (when you're OFF boost) you want the valve shut, then when you're holding back the boost it opens up. This is so you're pulsing the solenoid as little as possible, and avoiding holding it open for a long time, which can shorten its life-span.
In the case of bleed systems, you'd want a normally open valve, coz it'll spend most of it's time open.
The APEXI one in question obviously has both, useful, but overkill for this.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
