  • Replies 40
thanks peoples, will try and put a spec list up when i have some time, its a long list
the rear has the sit height as it has 255 wide drag radials on it atm and they are on rims with a big offset, trying to get some different wheels sorted
OMG! someone stole your A/C! lol nah seriously, that looks absolutely awesome. You've done us 32 boys proud... my only suggestion is that you put vertex side skirts on as well, the stock sideskirt looks a lil non flared to match the guards.
Oh and another vote for under bonnet inventory list.
Looks like you have your manifold cerammic coated. I would either make sure you have your dump etc wrapped in DEI exhaust wrap, or use DEI sheathing to cover your heater hoses on the firewall...that is if you still have a heater in the car:)
Oh and i repeat very tough,:rofl: i so want to gp down the same path with my car but dont have the courage:(
Awesome stuff mate, good to see it all coming together
Ready for the Nats?
About sometime there was a crazy 32 GTSt about! Something for the rest of us to look at for inspiration
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
