Jerry, how are you going for stock on these? I am getting sick and tired of recharging the battery in my car, so I wouldn't mind getting one shortly.
I don't have any but I can get them at any time as long as I get 5 to get them at $140 . If anyone else wants any I only need a couple of days to get them in .
West , if you have any problems finding posts, I can them for you here for about $18 for the 2 including the screws. Don't hold me on the price as its a long time ago .
  • Replies 376
Posted Images
  • 1 month later...
  • 4 weeks later...
what she said^^^^
if they are available still pls pm me, it is time for me to replace my battery.
thanks
O.K guys looks like there are a few of you that may want batteries .
I can get these at anytime as long as I order 5 at the time. All of you that want one please post here or P.M and I'll see what I can do for you. Price is still the same $140 pick up in Sydney ( or even meet up somewhere). For interstaters extra $20 for post in the eastern states and S.A. , W.A. and N.T. around $40 .
interested in buying one when you order next. i am located in sydney. can you still supply posts as well?
If you need posts, I should be able to get you some as long as you don't want the small posts that most Skylines have .
hey mate,
interested in a battery, but anyone from melb got one?
i'm interested to know where i can get terminals and the clamp?
would they fit a 180sx engine bay?
cheers
I'm sure you can fit it in the engine bay but I'm not sure what you need to mod to fit it. The battery is about the same length and height as your stocker but a little wider ( about 5 cm wider). You dont need terminals you can use eyelets and bolt them on the battery with the s/steel screws that come with it . If you want you can fit brass posts on the battery but I can only get the standard (bigger posts), if you use them then you have to change your terminals to the standard size, most Nissans have the smaller ones .
If you are keen I can send it to Melbourne, post will cost you $20 including rego and insurance .
  • 1 month later...
Has anyone squeezed one (or two) of these behind the trim in the boot on the right hand side of the car ? (as in where the jack sits but on the other side of the car) in an R33 Gts-t
I have seen people move the battery from under the rear parcel shelf into here, and I was wanting to put a second battery in as well in the gap and move the trim out a bit.
Cheers
Heath
  • 4 weeks later...
Just want to say that these sealed batteries are great.
I picked up one of these batteries from Jerry about a week ago as my old one one kept going flat after a week.
Installation was a simple enough process - just remove old battery and put new battery in its place and connect terminals by turning clamps sideways and screwing them down to battery terminals with the bolts supplied with battery.
There's no real need to purchase any battery posts or clamps. I just had to purchase a longer (7 inch) bracket to hold the bigger battery down ($4 from Repco).
I also cut a small sheet of rubber foam and placed it underneath the battery to stop any chance of the battery moving around as the original battery tray is not big enough to hold this battery.
Just about the only problem i had with the installation was that my rear strut brace had to be removed temporarily until i had installed the bigger battery as it could not slide through the gap like the old smaller battery had.
All in all i'm very happy with the new battery - Thanks Jerry. :worship:
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
