  • Replies 46
Id ask for an itemised list of what the $800 fee is for exactly...shouldnt cost that much to make it "just start"
Like Roy said, track down why the car wont start at the basics.....ie do the dash lights come on, does the fuel pump prime, does it actually crank but not fire? etc....
I will go see the mechanics tomorrow, its an rb25 loom.
Apparently the rb25 loom has to be pulled out and by using bits and pieces from the rb20 loom make up a custom loom to suit the situation.
I dont know if thats what needs to be done or not but thats what I am being told.
Thats what the $800 will be for.
If anyone has done this conversion before or knows anyone that has played around with the looms please let me know.
Thanks for all your help :(
Mark
The body loom (if thats what it's called) that runs on the drivers side of the engine in the r32 is a direct plug in on the r33 engine. It should be un touched with the knock sensors and air regulator valve removed form the eqivalent r33 loom and plugged in. In that situation the car should crank at the very least as the loom is un effected.
I would be checking that power is connected to the CAS, Injectors, Ignitor and coils as these will prevent the car from firing. Fuel pump obviously needs power but that is a fairly easy one as there is a single trigger wire from the ecu to the fuel pump relay that can be traced by looking at the r32/33 pin out diagrams. I'm pretty certain it's the same pin as well. Even with the fuel pump speed control, that i mentioned earlier, not connected the fuel pump will work.
As for a hybrid loom, thats a load of shit.
R33 engine loom will be used with the exception of the wiper section of the loom. You need to swap the main power plug in the front passenger corner of the loom for the r32 one and trace a few wires, and the same with the under dash plugs but thats it.
If you have the fuel pump speed control connected at the ecu you will need to wire in the dropping resistor and if you have a later r32 then there is a sensor on one of the heater hoses that needs to be wired in for your climate control to work properly but that it pretty much it.
guys, most of the info has already been covered.. and some of you have even posted in the same threads!
http://www.skylinesaustralia.com/forums/sh...ead.php?t=54983
http://www.skylinesaustralia.com/forums/sh...ead.php?t=53377
disco: i had a quick search and couldn't find myself.. but from what I remember being posted, for the sender you basically use the RB26dett top and screw into the standard bottom
As MR R32 stated, there are hours of fiddling. You have to trace wires and swap the dash plugs and the main power plug in the front corner of the engine.
But all the info you need is the pin out diagrams for both rb20 and rb25. The rest is just tracing wires from these plugs on both looms so you can connect it correctly. And then run the wiring for the other plugs i mentioned above.
I probably spent close to 6 hours on the loom when i did my conversion, not including the z32 afm and emanage wiring. But the car fired first go.
This is the second loom i have done, the first was for an sr20 into a cefiro which took a lot longer as i had to figure out what i was doing first and then run new power as the sr loom picks up its power on the drivers side as opposed to the passenger side.
I had these same drama's when I dropped a RB25DET into my R32. The Autoelec's bill was around $650. The engine now runs fine, however I still have these drama's:
* No Cold start
* No idle step up for Aircon
* No HICAS
* Front spoiler doesn't come down at speed
It's frustrating, because the engine dropped in with no hassles at all. The electrics however have proved to be a nightmare.
* No Cold start
* No HICAS
Couple of easy fixes and a speculator.
The cold start is fairly easy, just make sure your auxiliary air valve has power when the ignition is switched on as this is the only part of the loom that needs mods. Pretty certain i had to wire in power for it.
Idle step up for the aircon requires an additional relay wired into the loom triggered by the aircon on signal to the compressor. Power goes to the secondary valve next to the idle contol valve.
And the specky: No HICAS or front spoiler are probably related to having no speed sensor signal to the ecu.
Thanks for your input Dave, I was thinking the exact same thing about having no speed sensor signal to the ecu - as I also have no speed cut at 180kph.
Unfortunately I wouldn't no where to start trying to find the Auxiliary air valve, but at least I'll be able to give the Autoelec a heads up if I get a chance to drop it back in.
what's the total cost involved in a conversion (rb20 > rb25)?
It cost me around $6500. But you could probably do it for as little as $4000. My costs were:
Engine & Loom: $1900
Turbo: $600
Computer: $200
CES Front dump pipe: $650
Extreme Clutch & Lightened Flywheel: $1100
Adjustable Exhaust Cam Gear: $200
R34 GTt intercooler: $250
Auto Elec: $650
Mechanic: $1000
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
