Nice, bugger all difference between I and II... best thing over the regular R32 would have to be the brakes. Shame they didn't have an oil cooler though.
I think the old white JMS drag car was a V-Spec 1.
https://www.sau.com.au/forums/topic/62540-r32-v-spec-ii/#findComment-1183916
Apparently the easiest way to tell is the v spec's have cooling fins on the rear diff casing.
Actually it's the other way around...v-spec cars DON'T have fins on the diff cover. But that's not a reliable guide either as some late production non-v-spec R32 GTR's also came without the diff fins.
https://www.sau.com.au/forums/topic/62540-r32-v-spec-ii/#findComment-1184068
Other then the brakes for the Vspec I & II are there any other differences?
I've just bought an 89 and get it on monday. but as for the brakes I think the ferodo pads, braided lines and race fluid should help get them up to scratch
I have a question while i'm here though, what is the capacity of the GTR fuel tank??
my GTST was 55L so I assumed they were too but I saw a post for 72L the other day, that can't be right can it?
mark :D
https://www.sau.com.au/forums/topic/62540-r32-v-spec-ii/#findComment-1184656
Yep ATTESSA system is better on a vspec calculates much faster it's the same unit I believe that were fitted to the 33 GTR's . Other then Brembo's only other things I can think of is the vspec came with bigger 17inch wheels from the factory and maybe an oil cooler but don't take my word on that one .
https://www.sau.com.au/forums/topic/62540-r32-v-spec-ii/#findComment-1184696
Yep the tank is a tad over 70L, and putting around daily driving I get about 320km (mine is modified though). Most people I know with standard ones are around the same, 400km off a tank if youre really pushing it.
RB26 = thirsty mofo :D
https://www.sau.com.au/forums/topic/62540-r32-v-spec-ii/#findComment-1184880
The R32 GT-R V-Spec got:
The afore mentioned BBS 17x8JJ rims with 225/50 17 tires, the Brembo 324mm brake upgrade, quicker reaction ATTESA-ETS tuning, and metal compressor/exhaust wheels in the turbos. Colors: White, Dark Blue, Black, Silver, Gun-Grey Metallic, Red Pearl, Greyish-Blue Pearl.
The R32 GT-R, the V-Spec, and the V-Spec II were made alongside each other from Feb '94 through to Dec '94.
So, the R32 GT-R: released Aug '89, ended production in Dec '94
The R32 GT-R V-Spec: released Feb '93 through to Dec '94
And the R32 GT-R V-Spec II: released Feb '94 through to Dec '94
Other differences i believe were the computer, suspension upgrades including torsion bars, push pull type gearbox.
Difference between Vspec and Vspec II was that the supsenion was set for Le Mans on Vspec II
https://www.sau.com.au/forums/topic/62540-r32-v-spec-ii/#findComment-1185916
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
