Nice, bugger all difference between I and II... best thing over the regular R32 would have to be the brakes. Shame they didn't have an oil cooler though.
I think the old white JMS drag car was a V-Spec 1.
https://www.sau.com.au/forums/topic/62540-r32-v-spec-ii/#findComment-1183916
Apparently the easiest way to tell is the v spec's have cooling fins on the rear diff casing.
Actually it's the other way around...v-spec cars DON'T have fins on the diff cover. But that's not a reliable guide either as some late production non-v-spec R32 GTR's also came without the diff fins.
https://www.sau.com.au/forums/topic/62540-r32-v-spec-ii/#findComment-1184068
Other then the brakes for the Vspec I & II are there any other differences?
I've just bought an 89 and get it on monday. but as for the brakes I think the ferodo pads, braided lines and race fluid should help get them up to scratch
I have a question while i'm here though, what is the capacity of the GTR fuel tank??
my GTST was 55L so I assumed they were too but I saw a post for 72L the other day, that can't be right can it?
mark :D
https://www.sau.com.au/forums/topic/62540-r32-v-spec-ii/#findComment-1184656
Yep ATTESSA system is better on a vspec calculates much faster it's the same unit I believe that were fitted to the 33 GTR's . Other then Brembo's only other things I can think of is the vspec came with bigger 17inch wheels from the factory and maybe an oil cooler but don't take my word on that one .
https://www.sau.com.au/forums/topic/62540-r32-v-spec-ii/#findComment-1184696
Yep the tank is a tad over 70L, and putting around daily driving I get about 320km (mine is modified though). Most people I know with standard ones are around the same, 400km off a tank if youre really pushing it.
RB26 = thirsty mofo :D
https://www.sau.com.au/forums/topic/62540-r32-v-spec-ii/#findComment-1184880
The R32 GT-R V-Spec got:
The afore mentioned BBS 17x8JJ rims with 225/50 17 tires, the Brembo 324mm brake upgrade, quicker reaction ATTESA-ETS tuning, and metal compressor/exhaust wheels in the turbos. Colors: White, Dark Blue, Black, Silver, Gun-Grey Metallic, Red Pearl, Greyish-Blue Pearl.
The R32 GT-R, the V-Spec, and the V-Spec II were made alongside each other from Feb '94 through to Dec '94.
So, the R32 GT-R: released Aug '89, ended production in Dec '94
The R32 GT-R V-Spec: released Feb '93 through to Dec '94
And the R32 GT-R V-Spec II: released Feb '94 through to Dec '94
Other differences i believe were the computer, suspension upgrades including torsion bars, push pull type gearbox.
Difference between Vspec and Vspec II was that the supsenion was set for Le Mans on Vspec II
https://www.sau.com.au/forums/topic/62540-r32-v-spec-ii/#findComment-1185916
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
