Can Red Light Cameras Give Speeding Tickets ?
Im just wonder can red light cameras give speeding tickets theres a camera on the corner of bornia rd and mountain hwy. (not on the side of the road one of those mounted ones on the big poles) I ran throught it at a certain speed that i wont disclose..LoL
but the light was green and it flashed me ? do i get a speeding ticket if i did i would loose ma liscence ? can this happen ? with a red light camera ?
yes, and most of them these days are dual cameras.
there are dual cameras on mountainhwy/wantirna rd and bornia rd/wantirna rd. So i would have thought there would be one on mountain hwy/bornia rd, but it isn't mentioned in the below site for those 2 roads specifically, but all of those roads are pretty close together.
http://www.roadwatch.com.au/speedcameras.asp
haha my mate got pulled over by the cops for "running a yellow"... funniest bit was... they pulled him over for speeding up through the yellow BUT not exceeding the speed limit
Most of the red light cameras are duel speed/red light these days, i'm always paranoid driving through any set of traffic lights... your best hope is that they had run out of film in the camera/it wasn't full operational yet.
Best thing to do is to get petrol powered angle grinder and cut the thing down before they remove the film. :P
I'm pretty sure that the new camera's are digitally linked to the head office. So your fine will be being processed b4 you get to the end of the street.
Maybe now you(tintin) will learn to keep to speed limits and respect the law.
erm. no i dont think they are linked to the headoffice. and get the fine processed in real time. thye probably connect to the cameras end of the day download all the info and them do the dirty work..
lose your licence??? you must have been really travelling? no offense mate but if you were going quick enough where you think you're gonna lose your licence, maybe it was good you got zapped.... may have saved urself and others from something bad happening later on in your driving life...
or maybe you just have 1 point left and anything like 63 will mean u lose your licence...
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
