Now for pure rice factor, what do you guys think of these. Few places selling them on international ebay and also worksauto sell them for $150.
What do you think of the safety issue, like.. is it gunna get sucked in and blow the engine up from the inside? :D
ALSO, it says its easy to install, has any1 know of any1 who has installed one?
EDIT: Sorry.. i was sure I put the link in the first time
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WD2V
http://www.worksauto.com.au/catalog/produc...db14bbd4005a9fd
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33630
https://www.sau.com.au/forums/topic/63139-rice-factor-what-do-you-think/
Have wat installed?
Just think of the roar of your engine...the heat of the flames, the envy of the street, the melted paint you'll be dealing with, DEFECT after DEFECT after defect,
oh... and let's not forget the massive tank of fuel sitting in front of these flames, call me crazy but in my course of life fire and fuel aren't a good mix when you're trying to drive somewhere or impress some girls.
See if you can answer this multiple choice question.
the 'flame thrower' has;
a) been around for a very long time
B) burnt plenty of people
c) increased police revenue
d) made people mildly more amused than igniting one's own farts with a lighter
e) identified it's owners with the colapse of the mental health system
f) all of the above.
if i saw one of those on a skyline..
i would... flip out and KILL!!!
on a scale from 1 - 10
ten being really homo
i rate it at 10000000000000000000000000000000000000000000000000000000000000000000000000000000
00 x 99999999999999999
99999999999999999000000000000000000000000000000000000000000000000000000000000000
000000000000000000
so that is so homo i cant even fit it on a calculator to work that out!!
dad did that to his car when he was like 18 (ie. 70s) all u need is a fuel line, a tap on it prolly use relays and that stuff nowadays tho,a spark plug, and woo hoo. flames. good way to void your insurance, attract attention (cops and d!ckheads)
But to answer your question, as far as rice goes it would look kewl till u burnt sum1 and got sued.
best of luck to ya :)
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
