Now for pure rice factor, what do you guys think of these. Few places selling them on international ebay and also worksauto sell them for $150.
What do you think of the safety issue, like.. is it gunna get sucked in and blow the engine up from the inside? :D
ALSO, it says its easy to install, has any1 know of any1 who has installed one?
EDIT: Sorry.. i was sure I put the link in the first time
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WD2V
http://www.worksauto.com.au/catalog/produc...db14bbd4005a9fd
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33630
https://www.sau.com.au/forums/topic/63139-rice-factor-what-do-you-think/
Have wat installed?
Just think of the roar of your engine...the heat of the flames, the envy of the street, the melted paint you'll be dealing with, DEFECT after DEFECT after defect,
oh... and let's not forget the massive tank of fuel sitting in front of these flames, call me crazy but in my course of life fire and fuel aren't a good mix when you're trying to drive somewhere or impress some girls.
See if you can answer this multiple choice question.
the 'flame thrower' has;
a) been around for a very long time
B) burnt plenty of people
c) increased police revenue
d) made people mildly more amused than igniting one's own farts with a lighter
e) identified it's owners with the colapse of the mental health system
f) all of the above.
if i saw one of those on a skyline..
i would... flip out and KILL!!!
on a scale from 1 - 10
ten being really homo
i rate it at 10000000000000000000000000000000000000000000000000000000000000000000000000000000
00 x 99999999999999999
99999999999999999000000000000000000000000000000000000000000000000000000000000000
000000000000000000
so that is so homo i cant even fit it on a calculator to work that out!!
dad did that to his car when he was like 18 (ie. 70s) all u need is a fuel line, a tap on it prolly use relays and that stuff nowadays tho,a spark plug, and woo hoo. flames. good way to void your insurance, attract attention (cops and d!ckheads)
But to answer your question, as far as rice goes it would look kewl till u burnt sum1 and got sued.
best of luck to ya :)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
