Hey guys i recently had a system installd by GL pro sound
Got put in 2 12"inch rockford fosgates, splits at the front and 2 rockford amps
Now my boot rattles like hell
GL pro sound tell me u cannot get rid of the rattle
Is there any way i can reduce the rattle or eliminate it totally??
Id appreciate the help,
Thanx :D
https://www.sau.com.au/forums/topic/63241-boot-rattle/
Check your number plate, that usually makes the most noise.
You can sound deaden the under side of your boot lid. Check all screws/bolts are tight. Check the jack and tool kit, they will make some noise!
If your bootlid rattles, try looking for a thicker rubber seal so you almost haveto forceit shut.
They are wrong, there is alot you can do :D
Hope that helps!
https://www.sau.com.au/forums/topic/63241-boot-rattle/#findComment-1190470
$110ish for a sheet of quality sound deadening like serenity max.
while you are at it, buy 2 and deaden both doors.
tighten every nut and bolt you can get a screwdriver or spanner onto.
tighten the jack as previously suggested.
if you are superkeen pull the back seats out and replace the parcel tray with mdf.
and if you are superdooper keen install sound deadening under the back seat.
you should have Nissan Skyline R33 Infiniti after all this.
https://www.sau.com.au/forums/topic/63241-boot-rattle/#findComment-1192595
glps really said you can't do anything to fix the rattles???!!!! surely not. boot rattles are pretty much par for the course with a decent system w/o sound deadening in most cars and i'd imagine most shops are well aware of this.
whats rattling (if is the bootlid) is the frame. get some non-acitic silicone (otherwise it'll corrode) and run a bead between the outer "skin" and the framing. go nuts and do it properly. what you want to achieve is to isolate the two from each other. then you want to cover the whole of your bootlid underside in a good quality sound deadener (g-spot is the one to go with) and re-carpet it.
if you don't want to do it yourself, you should have a chat to marty @ fhrx studios. he's on these forums and based in sydney. shoot him a pm. he's deadened many a japper (inc his own s15) and knows the ins and outs.
d
https://www.sau.com.au/forums/topic/63241-boot-rattle/#findComment-1203758
  • 1 month later...
GL Pro Sould are pros, i carnt beleive they told you that .. yes as everyone has told you sound deaden everything .. you used to be able to buy this stuff called SOUND OFF professional damping for high performance car audio, you could buy this stuff in brush on and in sheets. You need to do the inside of your rear quarter panels and the boot lid, run some seam sealer in all the seams of the re-enforcements on you boot lid and either brush the deadner on the whold underside of your boot or cut out a sound deadner sheet and glue it on .. i would recomend using the brush on stuff instead of the matting.. its amazing what a difference it makes ..
https://www.sau.com.au/forums/topic/63241-boot-rattle/#findComment-1269262
  • 3 weeks later...
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
