Hi,
I have a Trust TD06--17C turbo for sale. It is a T3 flange, internal gate.
Good upgrade for RB20, RB25, RB30, Rated at 380ps according to various websites.
Good condition
$650 postage included.
In Melb
Hi,
Good condition
In Melb
does it fit into r33 gtst? ie. any other mod to the oil and water lines & dump pipe?
how many rwkw is it expecting? the condition of the turbo? thanks.. :rofl:
Hi,
I have only had this turbo for a few days and the reason why I am selling it is because I have just sadly sold my car and have no need for it. I was planning on putting it on the car but the new owner wants to keep the car relativly standard so he does not need it. As I have just got a company car I have no need for it so it is priced for a quick sale. It is rated at 380hp so it should make mid 220 plus at the wheels.
It has a tiny bit of play but completly normal for is age. It is a good power upgarde with out having to do any internal work, bolts straight up to 32/33 GTS-t. Comes with internal wastegate.
Cheers
Jamie
id love to strap it on my rb25 but i search for hours and hours on any info and dyno charts etc for td0617c on rb25det and found nothing, its more suited for rb20 i dont think it will run well on rb25det, possibly just surge
paulr33 you are correct this is a GREAT upgrade for an RB20det...
Done the research... This is perfect for an R32 silver top.... Not a good enough upgrade for a 25 motor.... You would be better off with a standard turbo high flowed...
So not to hi-jack this thread but yeah R32 owners this is the turbo for you... If you want a cheap bolton upgrade...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
