WRX Club - Rnd 2 - Phillip Island - March 12
  • Replies 290
So far the offical list contains the following people:
Snowman
heartbrkr
Roy
Ant95
pontiff
Since the list was posted (Friday night) ferni and Scotsman have sent in forms (that I know of)
It needs new turbo gasket, new EBC and a re-tune. If i was having a good monring at work i would have bought some brakes which would not have been fitted in time...but work sux again right now and i want all the money i can get in the bank. The projects im on wont die:(
Provided Ben can tune my car late this week, early next week and he doesnt find any problems then i should be ok. I want the susp to be given the once over as well as there is a knockign noise int he front right that is a bit unsettling:(
Ok have started an accomadation thread since it looks like it may become a logistical nightmare if we leave it too late.
If your planning to stay on Phillip Island between 11th - 14th post your details here.
http://www.skylinesaustralia.com/forums/sh...802#post1230802
Geoff will be there denham (I presumre) and also Anthony (heartbrkr) has one too - although to be very different his is a stock Auto!
sweet, what power u running now andrew? Nige told me ages ago you were getting a GT30 a bit bigger than mine, but that was back when u busted ur tranny.
Yeah denham looks like the R33 gtsts are in short supply for PI....I believe (according to my understanding) you should be running in the modified class (aftermarket inj + turbo) and I'm running in the std class but if you are still running street tyres it might be a close on track battle :)
r u using cheater tyres?
Denham......nah mate still on the cr@p (and I MEAN cr@p!!) street tyres. Had a look at them after Calder and theres a lot of wear on the insides of the tyres.....means my SFA traction has gotten worse :)
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
