Stupidly I started looking at wheels...
Now I've always been a fan of dished wheels but have been without with my current ride, as she came with already big wheels and good rubber.
At the moment she's wearing 18x9's all around with 235/40 rubber.
What I'm looking at getting are 18x8.5 235/40 fronts, and 18x9.5 265/30 rears.
Also, I guess the wider rears would help with traction.
Anyway, this is what she looks like:
and this is what she could look like:
Help! What do you guys reckon?
wil..
https://www.sau.com.au/forums/topic/64191-wheels-to-change-or-not-to-change/
Do it! The 2nd pic looks awesome =)
Dont put this off you getting the rims, but as far as better traction - tyre compound/brand plays a more important role than small changes in width... obviously going from something heaps skinny like 6.5" to 9" is going to improve it heaps (actually it depends, because in the rain you have more water running over the surface... but that all comes down to the tyre design too) - adding an extra .5" for more traction, you may find going to a diff tyre brand would help more...
Currently have Pirelli P-Zero Rosso's on all 4 wheels.. Sticky, expensive rubber...
There might only be 0.5" in width on the wheel, but the tire sizes are different, 235 vs. 265.
The 235/40 foot print is alot smaller than the 265/30 foot print isn't it?
Yeah, P-Zero's are good in the wet, and yes - there's a fair size difference in the tyre footprint, but I was just saying - if you're using cheap-ish tyres and want better traction, sometimes you can find a better improvement from going to different rubber than going up in rim width.
I wasn't saying anything against going up in the rim width at all - i was just highlighting that if you're after better traction it can be something (cheaper, sometimes) to consider.
EDIT: Obviously you understand that - so it's all sweet and my post was pretty much useless then :(
Anyway, the rims really do suit IMO - however some might say white/white has been done and done again - but don't let a "common" style put you off changing. All that matters is if you're happy with your cars looks .
hey yeah blitz, I noticed you changed your rims to 34 GTR ones. What made you change them?
I'm still undecided. I don't want bling.. I reckon the white with silver lip looks kinda racey. I also like the little bolt things. But yeah, $1900 for a mod that isn't really needed, but does make it look a lot better (to me anyway)... I dunno..
Don't bring, ecu, turbo etc into it... They're all coming.. ;) But still. Ah well. I'll figure it out.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
