the faq covers "hung on apexi logo"
15volts its too high, dead fuse for regulator circuit (i had this problem in my 33) theres a fuse in the boot for the regulator signal, its dead or removed, check it. engine light will only be on if you use boost kit without actually having the boost kit, it sounds like it may have done factory reset. if so turn off the boost kit under ETC, FUNCTION SELECT.
are you in melbourne ?
and unfortunately i cant do much with it as i dont have a commander for this. There are 2 types of hand controllers and it seems i can only get my hand on the wrong one!! thats why the apexi logo hangs. Also found out that a couple of people who have had to jump start or had dead flat batteries with power fc's have lost their maps in the process.... I fear that this will be my fate too. Flat broke so if that is the case the ol 33 wont be on the road for quite some time!! lol Getting alternator back tonight from a reco (needed it bad!!) so will put that back on and let you know what she's up to from there!!
you wont loose the map if your battery is flat or if you jump start it. the tune is saved in nvram. i fried my powerfc (blew it up by shorting the wrong wires) and i had it repaird by a friend at work and my tune was still present.
i have datalogit so i can access your powerfc but i can't tune it for you (no dyno). dr drift in melbourne has access to datalogit (and dyno) and he can tune it for you no problems. it just may take longer with no hand controller
give him a call
added djetro info for other djetro models (evo lancer, s15 200sx, gtr)
added wideband tuning
added full menu options for all powerfcs
added idle hunt / idle surge fix
added FUNCTION on / off japanese character key
updated some of the self tuning for ignition timing areas
updated idle reset procedure
updated info for apexi powerfc pro discontinued
  • 3 weeks later...
an important update is coming soon
re: starting issues with 414-AN012 (was a once off problem, not a bug)
active lsd on ecr33 FIX
for those active lsd customers check out http://www.skylinesaustralia.com/forums/in...pic=107656&st=0
Ok, got regualtor fixed, reco'd the alternator only to read your post about fuse, and guess what.... you were DEAD RIGHT!!!! Replaced fuse, all is good, still have the engine problem though. Seems ok under load, off load (ie: cruising at set speeds) it misses and farts at a certain interval, like every 3 seconds, it farts for 1 second, then fine for 3 seconds, then farts for a second and so forth. Finally got hold of a hand controller thats for an r33, and ......NOTHING! Apexi logo hangs, but i did find that if i hold up button whilst turning ignition key on it goes to a screen that just says "FN" ????
Think i may have fried some or all of the power fc? Googled the shit outta "power fc FN" etc only to come up with didly squat...nothin!!!! Help me please!! lol So far you've been spot on the money! If need be i'll express post it to you and you may be able to fix it!! lol, the problem i have is its supposed to be in a wedding march 18th!!!! not looking too good!!
i have tried looking into all of that, what i've found is this, which is just what "i think may be right".
That for r33 skylines there are in fact 2 power fc's around for them, one is serial ECR33 XXXXXX and the other is RB25 XXXXXX, the ecr33 one uses the hand controller FCC3 XXXXXXX and it looks like the RB25 (my one) uses a controller FCC NT XXXXXX
I cannot see anything on the controllers or power fc units stating numbers anywhere near 414 N001 or X001. Mine says PFC RB25 -9705 - 0013 on the unit and the hand controller says FCC3-020-10512
Man, im glad you've got the brains to figure out this stuff!! That bloody FAQ you've done is a credit to ya and it would have taken a LONG LONG time to get to the stage its at!!
so the pink & black soleniod wiring is wired into the factory soleniod loom green & blue/white wires ? is this correct ?
is the z32 afm from the vg30 engine, so what voltage value do i use ?
Also ive got 555cc nismo injectors, what value do i need to use in the injector value menu ?
Hi Paul,
Just a though here, don't shoot me down in flames :laugh:
How about you add a section on doing full power ignition tuning? As long as you have a good set of knock headphones, it isnt too hard. I know of a few cars that have been 'street tuned' this way with a wideband O2 meter as well.
Cheers,
Matt
whilst i wouldnt mind myself
its basically a case of up timing and watch for knock
i can put lots of stress on the car
and also its a big change of the tuner "amatuer" to really bork the engine.
i would rather a pro do that part if it makes sense
very interesting read, thanks for all the info, i have tried some of it, but im still not confident im doing the right things. Anyone in Sydney know a cheap place to tune the power fc properly ?
  • 4 weeks later...
im assuming rb20 powerfc would suit which is an ap engineering model.
the 4wd controller system is performed by a seperate computer to the ecu. you may find the tps signals and rpm have to be run manually as the rb20 ap engineer wont expect to have an attessa ecu piggyback-ing off it
  • 3 weeks later...
    • Inspiration: https://www.nissan-global.com/EN/HERITAGE_COLLECTION/Primera_GT.html   Original ad for the car:
    • Yeah, hard to find and a pain in the ass to change with the transverse engine. I’ve worked on a GTiR before and it’s not a job I’d ever want to do again. theres a company in South Africa that makes RS3 gearbox adaptors for the AWD SR20 including gearbox mounts, so I could modernise it and go a dual clutch with paddles. For now tho, it ticks all the boxes. Super cheap, can throw the kids and their junk in the back, and SR20 that I can turbo cheaply, a CVT that’s not a dog’s breakfast like the V35, and has 80% interchangeable parts with stuff I can source from the wreckers cheaply…. But it’s still unique. I love the wagon back of the Autech version. It’s cheap enough that I can buy another stock manual FWD Primera with SR20VE, swap the gearbox to the N15 pulsar short gear ratio box, swap out the brakes to the R32 ones I pulled off my 32, register it on club plates and take it racing. $1300 shipping from NZ. Heaps of parts and aftermarket builders for transverse SR20’s in NZ.
    • Hard to say, just pop the rocker covers off and have a look if you think it's cammed. You probably need to replace the valve cover gasket/half moons anyways.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
