  • 3 weeks later...
Awesome thread Paul. Well done.
More info than i'll ever need.
Just a thought for anyone with a blown Power FC, that is having probs getting it fixed:
The boys down at 'Access Autoworks' in Vermont, Melbourne (used to be in conjuction with 'Hypertech', who now no longer exist) may be able to help out. Only reason I say this is because i have an ECR33 Power FC currently on its way to Japan to be fixed up. It was blown when trying to install into my R32 GTS-T with RB25 transplant (Jap conversion) and wiring was up the creek.
So if you cant get one fixed, rather than throwing it out, or buying new one, give them a try.
very nice write up. very very handy.
when installing.. do u recommend warming the car up then installing the PFC or just bolting it in and warming it up with the PFC? i ask as does it need to learn its own cold start?
im about to get a 1995 R33 GTST i think they have a Series 2 engine as its a Series 1.5 so is ther a Different PFC for the series 1 and 2?
the car comes with one not installed is ther a way to verify it is the right PFC for the car?
thanks in advanced.
mark.
there is no difference between series 1, 1.5 and series 2 for PFC
33 gtst model suits all. you should warm the car, the install the powerfc and perform the self idle lean procedure (covered in the FAQ)
I plan to install one in my mild modded GTST and run it on base maps for a month or two whilst I save up the cash for a tune. Am I gonna have problems starting it in the mornings and stuff?
I am about to install a 2nd hand PFC... And im not sure if it has a tuned map in it.
If it has a non-stock map will it still perform the self tune setup? is there a way to get it back to base map?
Thanks
thanks paulR33 its a very good read. i read nearly all of it. it doesnt mention to warm car up prior. i just assumed and asked for confirmation.
What type of fuel economy will it be like with the base map? without touching the AFR aswell? just a straight bolt on.?
thanks a bunch
mark.
I have a SAFC installed on a standard R33 GTST ECU.
Is the base map on the PFC exactly the same as the standard ECU?
Would it be a problem if I install the PFC and keep the SAFC in the car until i get it tuned?
Is there a way of copying the settings from the tuned SAFC to the PFC.
Maybe by writing all the details from the SAFC on paper and then input these settings on to the PFC.
I do not realy know or the setting options are almost the same between the SAFC and the PFC.
Thanks in advance
Gijs
thanks a bunch
mark.
fuel economy will be ok ish providing you have a working 02 sensor
Thanks in advance
Gijs
no the stock map on the powerfc is not the same as the stock ecu map
it has a bit more tuning and a little bit leaner afrs probably.
when you get the pfc, remove the safc completely (and sell it).
you should not need to run both, nor is it a good idea to.
the safc is simply correction values for 20 load points, its not a complete map so no, the data is not compatible.
i was tempted to order an rb26 powerfc tonight and wire it up to my rb25 and write up a quick howto so for those looking for powerfcs on their r33 could simply follow the steps using a new rb26 PFC but i have some concerns
1) duplexing the afm input to the 2nd afm pin
2) duplexing the 02 sensor input to the 2nd afm pin (if wanted)
3) altering the injector settings to suit rb25 370cc instead of rb26 440cc (so possibly negative correction or latency??)
4) getting a working VCT setup (friend suggested buddy club device $90)
if anyone is willing or interested to work on some of these it coudl be helpful for all
Hey Paul,
Had my FC in for about 4 months now without missing a beat.
Get the occasional orange light pusle on the engine light for the standrad, reaching max levels warning. (no problem)
Today, for the first time, the engine light has lit up but stayed hard on for about 20 secs.
It happenned when coasting down off the throttle, and on another occasionally when sitting on idle.
Idle was fine, revs were fine, everything seemed as normal.
All temps, oil, all good. No other lights.
Anyone encountered this before?
Maybe a faulty sensor? (i hope)
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
