Paul,
Would a dodgy AFM cause major knocking in the range of 70-90?
unlikely so i would say no, read the PFC FAQ
theres lots of topics covering knocking and how to test and deal with it
Does a power fc'd skyline need regular "tuning", like changing the oil every 5000 ks?
of course
normal maitenance should still apply for the car
if the car is putting out significantly more power than std more attention should be given to service intervals and quality of fluids, items used etc
Is there a way of disabling one cylinder through the power fc making the whole engine run on 5 cylinders?
Went to get my car tuned, but they never tuned it as my engine was running 5 cylinders.
there is no such feature, the only way you could achieve this would be to unplug one of the coil pack leads
Hey paul,
I've notcied that on my powerfc controller that my knock "figure" has disappeared... I still get the knock bar I just dont get the knock value. Any suggestions?
This problem only happened when i was driving home in flooded roads and I had hit something which made a pretty big thump but at low speed (mabye 10-20km/h) which has then caused my immobiliser light to come on whilst driving and now my alarm/immobiliser doesnt work.... Would this have something to do with the missing knock figure because I havent touched the pfc controller since I got it tuned...
Hey guys i have just put a power FC In my R33 and i am having trouble with the fuel and ignition map when i adjust them and then select previous and exit the maps then return to the maps the adjustments i made are gone just wondering if any one can help me
Hey paul,
when viewing knock in 1 CHANNEL display press UP for digital top score
i've replied to your pm - when you edit a value on the INJ or IGN map you need to confirm the change with NEXT (PREV will back the change out)
so edit the value, press NEXT and it will save the change you have made
paulr33
Hello, i wrote you few time and sorry for disturbing but i need help, i need to tune somehow PFC but i dont know how to:( i read manual but no sence:(
here is list what i have instale on the car it was absolutly stock when arrived
FC
front mount plenum
KKR480
intercooler
full hightflow exhaust
injectors maf and pump is stock
so here is my problem i cant close westgeit because of othervise boost goes up now i have arraund 15PSI but turbo opens at 4500 RPM and eache run up i have erraund 90 knock, fc is absolutly not tuned just moving timing at 6 degrees and thats all
if you can help or give some nmaps that i could enter in fc it could be great or suggest someone who can help me... car is runing well its much faster than M5 E60 but still FC isnot tuned and i know its not good for engine
Please Help
Any other recommendations for a unstable and sometimes high idle (1000rpm)
I have leaned the idle right out and it definately helps when rolling to the lights as before it used to rev up and down. Now at idle, sometimes its fine at 700rpm but generally its around 900/1000rpm and sometimes back to 700rpm, but the majority of the time its high, seems to have a mind of its own.
Any recommendations as i dont want to reset it.
Hey,
With a r32 gtst and rb26dett ecu.. I am having troubles with speed read out. It sais up to 900km per hour when only doing 100 sometimes it works good and others none at all. Any idea??
when you encounter the high RPM issue check out SENSOR SW CHECK and see if anything out of the ordinary happens
maybe leave that screen open and watch if you see the issue about to occur
other than that all i can suggest is maybe clean AAC, check leaks etc, check TPS, check throttle body
read the nissan service manual for idle related issues and lastly a reset as a last resort (get someone to copy the tune before you do)
Hey,
the only thing i can suggest is check the speed sensor wiring
Not sure if this has been asked but I don't have time to read through 21 pages so...
Can the 3 or 5 pin harness for the boost reading work on any pfc or just the d-jetro? Also, what else do I need to hook it up apart from this harness? Vacuum hose etc??
hello stranger
:P Small world isnt it!
Im quite sure you can use the boost reading on any pfc. I know mine is 3 pin and the socket is on the back somewhere. In my pfc boost controll kit it came with the sensor, which is wired in and hooked up to the manifold pressure. Im unsure of the signal type this sensor uses and what else you could use but i imagine there'd be something else out there. . . .
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
