Hi, can anyone here clarify the rules about having an after market gear knob? I heard that for it to be legal, there must be a H Pattern on the Gear Knob.
But what if I have a H Pattern Sticker nearby? Will this count?
I read somewhere that it is ok in NSW but how about over here in VIC? Anyone knows?
https://www.sau.com.au/forums/topic/64227-laws-on-aftermarket-gear-knob/
I've had my car RWCd several times, and it's fitted with an aftermarket gear knob that doesn't have the pattern etched on it. I've never had comment from the RWC guys that it's a problem.
Frankly, anyone who needs the gear pattern etched onto the gear knob to know where the gears are doesn't deserve to be driving, period, let alone driving a manual.
I believe that a few people here have been defected for not having the shift pattern on the knob. I dont know about having the sticker near it though.
Also, as many people know, what a cop defects you for and what the RWC guys say are totally different.
Does anyone sell these stickers? Thats just a stupid law.. as if you wouldn't know the direction of 1st, 2nd, 3rd and the rest of them
Its based on the idea that if there is a life threatening emergency and someone needs to use your vehicle, they need to know which gears are where. The reverse gear is not always in the same place
lol well thats definately the bush mechanics way to do it :)
maybe even just texter it on ya dash haha
just go to a printing joint and get one made... maybe i could get my uncle and aunty to make a heap up.
pen, paper, sticky tape...Problem goes away.
this is a good cheap fix
one of the excuses i recieved a defect was because my gearknob had no H pattern.
to fix it i just got someone to cut out a vinyl sticker with what i needed and its all done :)
stuck it just next to the ashtray
yeah, my bro's golf you have to push the gear knob DOWN, and then push it up to left, LEFT of where 1st gear is... something like that wouldn't be too easier to figure out if there was no pattern.
The other day i had to drive a Barina (don't ask), and the stupid thing had it so you had to pull up on the friggin gear boot to put in reverse! Now there was no pattern for *that* on the gearknob! Took me friggin ages to work it out.. stupid as.. damn girl cars are crap..
yeah, euro cars have the reverse on the left. it's a pain in the ass. It's also wierd, with indicators on wrong side, coz when you come to a corner, you use left hand for indicators, then have to shift down with same hand, just annoying.
they are definantly defectable, a friend has a nismo sticker nearby, im not sure where u get them, but they r definantly avaliable
i love the M3 gear knob which illuminates the H pattern at night time... that's cool :D
but yeah, don't go blowing stupid amounts of money on "Nismo" patterns, just gank the logo from somewhere, print the f*cker out with an H pattern, or just do the whole thing with pen and paper.... don't think it's worth spending lots of $ on...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
