Jesus chr1st. Its a T78-33d, they all use the same turbine, the 33d tells you what compressor its running. Once the turbo is removed he will be able to look inside the exhaust housing to see what number is cast into it to give you an idea of the exhaust housing size....for farks sake try reading up a little about the turbo instead of post bashing the guy.
If you have had a look at the Trust turbos you will realise its hard to come across wheel sizes and trims etc, LOL...if you find some compressor maps for the Trust as opposed to Mitsubishie wheels then let us all know
End rant...late night at work, even earlier start:(
https://www.sau.com.au/forums/topic/64345-t78-turbo/#findComment-1209903
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
