  • Replies 630
im going.
so is r31det, phox, jester, bluprint.
if the cops wanna stop street racing, they should build a motorsport complex for all the "hoons" (under which we are classified, against our own will) :bs!: , so we can do it in a safe environment. simple solution to a simple problem. are politicians thick?
YES.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
