Hi,
I was wondering if you guys could help me out. I wanted to know what turbo you guys would recomend for a RB25 that will be used for drifting. I am lookin at an external gate set up and want to make between 250 and 300 rwkw eaisly. I want to have strong mid range torque. So far these are my options.
2540 (Im thinging too small)
2835 (do people do this ive only heard of these on SR20s for drift, ie D1)
3037 (will this be too big or will the ball bearings make up for it)
3040 (didnt know they existed till recently, any thoughts)
TD06-20G (I know this is a good turbo for the RB20 but waht about the 25)
TD06-25G (this is the turbo im thinking of atm but I hear it doesnt come on boot till close to 5000rpm is this too lagy)
RX6? (BIG bucks and I know little about these turbos)
Any help would be much apreciated
Thanks
https://www.sau.com.au/forums/topic/64408-what-turbo-for-rb25-drift-motor/
For start's you don't need 300rwkw's to drift, 250rwkw's will be fine, with you car on a weight loss program... :)
External gate for drift ? - that limmit's you have a smaller & responsive turbo.
For more power on the track with Internal Gate I would go the HKS 2835ProS which is enough for 250 - 300rwkw's. Other wise go for the 2835 external version if you have to have an external gated turbo. Stay away from 3037's & 3040.
I personally would go for the 2530 or 2540 turbo.
:cheers:
Jun
For drift you only need a 2530, 2535 or a GTRS. These turbos will give you between 220 and 260 rwkw, more than enough for drift, with a whole bag of torque and response.
Have you done all the other more important mods first?
- Braces
- Suspension
- Control arms
- Diff
These are far more important than a turbo upgrade, as the standard RB25, with aftermarket ecu and boost, will have plenty of power on tap.
I am aiming for the car to be a high end drift car so I belive 300kw is about right due to the fact that the average D1 car is rated at 400ps at the wheels which equals 294kw and thats on 1100kg S13 platforms as aposed to my heavy R32 platform.
So from what you have suggested the 2835 is the way to go. If a 2835 can flow an easy high 200kws with good response I can see no flors in that. Do you know what they are rated to?
Thanks for your input so far guys.
I have been talking to some respectable tuners about this in great detail and they belive the 2530 and 2535 have to much back presure to easly run 250kw without rick of detonation, as for the gt-rs I have heard they are a bit miss matched and are prone to surging. Not trying to disagree with anyone here just telling you what I have heard so far. The 2540 has been recomended but I still love the thought of a external gate.
As for other mods to the car.
I removed all sound deadning.
Full 8 point cage to struts with side intrusion and seam welding goes in next week.
As much bull crap bracing as I could find on Yahoo JP.
UAS break upgrade
adjustabel camber front and rear
adjustable castor
subframe lock kit
extended steering lock kit
cusco 2 way diff
Tein HE coil overs
Rb25 box
Recaro seat
Harness
Custom Exedy clutch
RB25, just need the right turbo kit
Thanks dude.
Im installing a Power FC for now using the R32 loom. Then rebuild the motor in 6-8 months with forged pistons, rods and relive the block and head. At that stage ill go for motec. Its a great insurance policy in my books.
Great to see a properly set-up car :cheers:
The only mismatch turbo i know of is the 2540, I personaly would not use this turbo at all.  I would still use the GT-RS or the 2835.
What ecu are you running?
After a little more research tonight I think im heading towards a 2835ProS and aim for an easy 280kw with cams, head gasket and injectors.
What are your thoughts
I also like the look of this:
HKS 2835ProS
I also found this little document for your enjoyment.
HKS GT Ball-Bearing Turbochargers - Comparison Chart
Ok guys just a little update.
I decided to go with the 2835Pros.
It arives next week so stand by for some comprehensive dyno graphs with the following setup.
RB25DET
2835ProS
R32 Power FC
Z32 AFM
TOMIE 260 IN/EX Cams
Sard Fuel Presure Reg
Bosh 040
1.6mm Head Gasket
N1 Oil Pump
N1 Water Pump
Standard Injectors
Any guses on power on 1.1-1.2 bar
You dont reaslise who "adz" is i think :(
He has the car as he's in the "know" hehehe!
Adam, your going to need a set of injectors thats for sure.
I'd say look @ the Nismo 740's they are a straight fit and get rid of the problems the SARD RB25 ones have at times with the collars.
only a few $$ more expensive anyhow
You looking @ rebuilding the motor at all, an RB25 wont live long @ that power with the high end flogging your going to be giving it around calder/JMS comps etc.
cheers - ash
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
