The biggest issue i've been told that i will have with licencing this R32 is having an engine swap and v-mount cooler.
Anyone been through something similar? Offer me any info?
**Edit - Compliance and Engineers signoff done!!! This should mean no dramas about the 2 issues mentioned above from the pits.
  • 2 months later...
Just a little update...if anyone cares.
Engineers certificate a.o.k!
Went to the pits last monday and i think i got off quite lightly!
The bonnet is raised slightly, needs to be level with side pans, vents/pin holes need to be covered up.
I have to take the mech diff out...i thought i might be lucky and it wouldnt clunk when he test drove it, i was wrong :P
And I have to remove the hicas lock bar.
Almost licenced this baby! yay!
hmm.. i have a hicas lock bar and a raised bonnet too... i also have bonnet pins..
you had to change all that just for complience on an 89 model car?????
my car is currently being complied... like always i expoect the invoice to be much more then the quote i was givin :P
they are lot stricter over there, it has to go through a full inspection at the transport place before it can hit the road..
here they barely even look under the bonnet.
Compliance is all done. it wasnt done by a workshop, rather a highly recommended gent. I paid for the major stuff that i couldnt do (side intrusion bars, fuel neck restrictor, engineers signoff, child restraints etc) and chose to do the rest of the work myself.
good to see you got it all signed off!
when does it go to pits now?
good luck with it all
cheers
Adam
*takes a deep breath*
PASSED PITS TODAY!!!!!!!!!!
2nd inspection and not everything from first inspection was rectified.
Got permit for vmount, strut braces, carbon fibre bonnet etc!!!
Oh what a lovely day ;)
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
