HAHHAHAAHHA go check out his cardomain page http://www.cardomain.com/memberpage/777775
and look at the results from his stupid question of turbos vs V8 and TURBOS are killing him in the results ahhahaha
OH another thing he's babbling so much about a 5.7L car putting out high 11s and Perth has got 2.6Ltr cars putting out low 10's hahaha hell go hunt down Cypher in Myaree their 2L RX3 can go down the qrt in low 9's.
  • Replies 350
lol who cares.
in the end who the shit pays over $50k for a ford or holden? heh
if you want to pay.. pay... go drive it instead of posting on forums.
and if i could afford the petrol i'd have my 351 '69 XW GT back on the road.
horses for courses
hey also go hunt down the car MESMERIZE its abit closer to your engine litre, its a twin turbo Soarer that does low 11 on street tyres. and you can't miss the car its got a full Haleqain paint job.
anyone else in perth can recommend this fool some 10sec GTRs to do and try is wang at.
i work as a mechanic at a holden dealership and get to drive cars like yours which i would give a bit of credit if you wernt so up your self. i drive a commodore and a turbo civic and would choose a GTR over your car anyday but not cause i dont like your car but because a GTR would make your car handle like a barina. And whats your user name on street commodores forum?
http://www.skylinesaustralia.com/forums/sh...ighlight=ND4SPD
Oh another thing SkylineKiller since you like to read MOTOR mag, check out the Nov/Dec 2003 edition of which STOCK cars can actually hit 300kmhs not cause their speedos say it.
the Lamborghini Murcielago got 301 and who topped the list???..... a $40K R33 GTR STOCK that hit 305 and 306 kmh in its 2 alloted tries.
3 HSV cars were in it and none of them got close. The closest was a $120K yes $120K 1200kg CSV Mondo what pumps 375Kw Stock and it only got to about 280kmh so whats the point when its speedo says 320kmh top speed. Typical HOLDEN theoretic nonsence. Least FORD enthusiasts people are more clued on to what's happening in the car scene.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
