My car has a 6sp OS Giken seq gearbox,4 plate clutch and front and rear diffs
all made by OS,MY TUNER IS ALSO A VERY GOOD FRIEND sorted out a good deal
on these parts above.
here is my tuners web site www.osgiken.co.uk
Keith
i have but finding a 4wd auto box is another story, and someone to build it.
it was going to cost ~$4-5k any way, so decided it was either a os cross mission or pfitzner...and after speaking to Simon @ PPGearbox, my mind was pretty set.
looking forward to giving there box a try.
I will be looking into the pfitzner box soon Judd, so please let me know how you go.
Ross
Keith
Are you also using the OS 3 litre bottom end?
Duncan, yes, the other 4WD Nissan auto boxes can be used as long as they fit the Rb26 block.
Keith, how did you find the HKS 6sp? Abflub gtr smashed a gear at Sportscompact attack over the weekend? I have now seen Trust and HKS dog box's smash gears with ~400kw
Hi Judd
Sorry i missed you post
The HKS box is good as long as it dont smash the dog rings
i had a HKS 6sp box smash 4th gear and you cant buy the parts for it anywhere
the box has to go back to HKS in Japan and they have to do all the work :)
I was told that it needs a rebuild once a year if you want it to last ????
the time scale and the costs made me want to sell it asap,so i
could buy a gearbox that i could get parts for off the shelf here in the UK
so happens that my tuner and good friend is the main importer for OS Giken
www.osgiken.co.uk
Keith
Guest two.06l
Hi Judd
www.osgiken.co.uk
Keith
Hi Keith, Paul and Stacey here. We are trying a Pfitzner box in our drag r32 as well. We will let you know how it goes. Ran 11.2 (131MPH) on the weekend running full weight 3550lb with a stock gearbox and street tyres. High rpm shifting is very difficult without damaging the box due to the synchromesh setup. Looking at shedding some weight and fitting new box to get into the 10s. We also run HKS 2530 lowmount turbos on this car so a 10sec pass on these will be a real achievement.
Hi Keith, Paul and Stacey here. We are trying a Pfitzner box in our drag r32 as well. We will let you know how it goes. Ran 11.2 (131MPH) on the weekend running full weight 3350lb with a stock gearbox and street tyres. High rpm shifting is very difficult without damaging the box due to the synchromesh setup. Looking at shedding some weight and fitting new box to get into the 10s. We also run HKS 2530 lowmount turbos on this car so a 10sec pass on these will be a real achievement.
11.2 is a good time for a full weight R32 with a pair of 2530 turbos
there was a guy last month running a Pfitzner box in a R33 with big ish
power and the box went bang dont know what broke in it ??.
You should be ok with the Pfitzner box if you damage it you wont have
a problem getting the parts to sort it.
Keith
  • Like 1
  • 3 weeks later...
Keith - have you tested again since?
Hi Munro
I have been testing this weekend and have managed to run the time's below
Drag Racing Info Today 1/5/05
Keith Cowie....R32GTR
1/4 Mile....9.632 sec
60ft...........1.605 sec
330ft.........4.143 @ 112.66mph
660ft.........6.24 sec
990ft.........8 sec
terminal speed was 148.14mph
I am just home after a 10 hour drive,i will post more later
Keith :rolleyes:
That sounds like fun!!! Is the car behaving itself & staying straight now.
I went looking for old timecards & found this one -
60' 1.526, 330 not recorded, 660' 6.337 @ 117, 1000' 8.170, ET 9.637 @ 148.88
Best 60' to date has been 1.46. I think Keir is down in the 1.3s.
Keep up the good work, that would be getting close to the record in UK wouldn't it?
Hi Munro
Yes the car is going in a straight line now no problem.
Thanks Keith
Well where do I start.
Sorry for keeping this weekend a secret from everyone apart from Dave Wilkins
the reason for this was that I did not want everyone and there mother there expecting
me to run a good 1/4 mile time straight away.
We were having big problems with the car not wanting to go in a straight line when
on full power in 3rd,4th,5th and 6th gear,all I am going to say is that it was very dangerous
not knowing what way the car was going to go at 100+ mph.
On Saturday all we wanted to do was set the car up so that it would run a straight 1/4 mile
after playing with the wheel alignment and damper settings we had it going in a straight line
and it now feel's 100% safe to drive flat out.
The next job on Sunday was to get it to launch off the line,spent the whole day trying different
things with the Autronic software,but it kept bogging big time on the line
the car still managed to get up to 154 mph with a crap start,I was getting a bit annoyed that it
would not go off the start how I wanted it to,so I called Mark Shead from MAD and he told me
that the software needs another control box before the launch control will work as it should
part now on order from Autronic in Australia.
On the Monday I went for 2 slow runs to warm the engine and the transmission up then
I tried a run,it still bogged a bit with the launch control set at 8000 revs I did a 10.17
here is the times from the slip below.
1/4 Mile....10.17 sec
60ft...........1.801 sec
330ft.........4.628 @ 112.62mph
660ft.........6.81 sec
990ft.........8.591 sec
Terminal speed was 146.96mph
I was getting a bit pi$$ed off by now so I switched off the launch control and rolled up
to the startline again gave it everything off the line it took off,it caught me out a bit but I was
away without any bogging this time,everything was going ok until I missed 4th gear,I then
put it into 4th gear gave it everything in 4th then 5th and crossed the line,I thought it would be
another low 10 sec pass,I got a surprise when I was told I had done a 9.63.
we left the car to cool down a bit before running it again,we were about to run the car and the sky's opened
up and the strip was a washout,to say that I was gutted is a under statement I think the car could
have done a very low 9 sec pass on the day.
I now know that there is a lot more to come from this car and myself
this is the first time that I have driven the car in anger since TOTB and to drive it
flat out for the first time is very daunting to say the least
Very very happy
Keith
  • Like 1
Keith
my set up is very similar to yours
drag radials
hks drag suspension
1.5 cusco front & rear
900 odd ps (t51 r, giken rb 30, jun INT 69-11.35 BC 29 EX 68-11.35 BC29 cams)
midori top front adjustable camber mounts
cusco rear adjustable camber
urethane rear sub frame mounts
I realize that I am cheeky asking BUT I would really appreciate it if you would give me an idea of what camber, caster, toe in, damper setting's & ride hight to run, also tire pressure's. we should be firing up the car this week, unfortunately it will be a couple of months before it hits the track due to other commitments & the fact that its winter down here.Being a brit I have spent many a good weekend at the 'pod' do you remember the houndog funny car ? or Sammy Millar running a sub 4 sec quarter in his rocket ? about 1980, probably before your time ! thanks- John
Keith, well done. Massive half track MPH and huge trap speed. Those 60' times won't be so slow for much longer and then you will be all over a low 9 and hopefully knock-knock-knocking on an 8 with more development!
Very cool indeed.
Keith
drag radials
hks drag suspension
Hi Dicky
Can you send me your email address [email protected]
Keith
