er... when i get some money saved for it. i have almost all parts, just need to find time.
Oh and i'm waiting to get my brothers R33 registered so i have a car to drive around while it's in the shop.
i'm guessing within the next month or 2
  • Replies 297
Good work, Darrin.
Looks the same as the one in my car, which is apparently (according to Beastien) the series 2 console. It looks like it has the glvebox that opens both ways - either towards the driver or the passenger.
wow I just read that whole thing
there went my day ,
I do have a idea with the surround for the shifter, friend of mine had a guy do some custom plastics work for him in his liberty for his foldout head unit ect. was 100% mint work * ill dig the photos up later *
anyway . I’m thinking personally ill ditch the cup piece at the back . and have him put in the slot for the hand break and edit where the auto went to put the piece under there for the gear boot.
stuffed if I’m paying 2k for it all :)
I havent pulled mine apart yet. but how is it under the auto peice. ie, is there enouf room to mount the handbreak gear. is there much junk under there the auto shifter sits ?
`josh
Yeah there is not too much stuff under mine, and there is more than enough room for the handbrake, just make sure they weld yours in properly..... mine was held on with 2 or 3 tack welds that were done by an eplieptic monkey, so one day they broke, I havent got it fixed yet, not much use for a handbrake here in Rocky :)
Yep . got rid of my lovely s13 :)
only so far that much power on rwd gets you eh . wanted something bigger / and more potentional . let alone something newer * s13 was starting to get a bit old * plus still have a track s13 lol
So first move is to get rid of this shocking auto. Then swap the rb25 out for something with a bit more poke :D
`josh
Could someone please confirm if I have missed anything as I may be doing this swap over the coming weekend.
R33 GTS25 4WD Gearbox & Transfer Case (Push Type)
R33 GTS 25T Flywheel & Bolts
R33 GTS 25T Clutch & Pressure Plate
R33 GTR Quick-Shift Gear lever
R34 Clutch Pedal
R34 Brake Pedal
R33 Clutch Master Cylinder & Lines
Spigot Bush (for end of Crankshaft)
R33 Handbrake Lever Assembly
R34 Centre Console Assembly (to be fused with Stagea Console)
Do I need to pull my dash to drill the hole for the Clutch Master Cylinder?
So far I think I'm up to NZ$1500 in parts
Edited by tRUkbOY
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
