82 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 52
Heres some pics of my car with the GT wing just sitting on the boot.
Bear in mind the S1 spoiler is still attached(anyone know how to remove them??) and the GT wing would sit approximately 5-10cm further back than in the pics.
Does anyone know where to get CF bootlids for R33??
:D
You need to get a bosykit and some phat rims to make the wing truly apart of the car. It looks a bit out of place with the stock bodykit
I dont think I'll bother with a body kit but I will probably modify the front bar.
Might consider some rims later but the ones I got are decent -17's..... 255's rear and 235's front
I would've removed the stock spoiler before putting the GT wing on
I removed the stock spoiler today and I'll take a few pics tomorrow.
I've got a bootlid garnish thingy which I will leave on for something different.
Removed the S1 spoiler and Installed the GT wing on friday. Also went and got a quote to fill the holes and respray the boot for $550, a bit pricey but I've seen there work and they do a top notch job.
Heres some pics;
How hard was it to remove the old stock spoiler?
Quite easy actually. After undoing the 4 bolts I ran some fishing line between the spoiler and the bootlid(where possible) to free up the glue stuff and then simply grabbed the wing and pulled firmly upwards untill the clips released it.
y not just get r34 gtr spoiler?
Well scrap that idea. i made a promise last night no more buying fluff for the car. Have to start saving again...so only money to be spend on car is servicing and track days. Only if something breaks am i allowed to buy a new one:(
I think it looks alright and could potentially make the car as a whole look great. Of course it will fit in a lot better if you balance things out.. I recently got an immitation gtr front bar and i think it added heaps to the look of the car. It did cost a bit though - almost 1k inc. painting, installation and mesh. Maybe you should go for a 400R bar. That's a little bit fancier.. it will suit the wing better. But then that might not look quite right until you get some new side skirts.. e.t.c. e.t.c. So much money!
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
