I have merged all the picture/gallery issues threads into one
Yes we know about it :domokun:
Yes we are working on fixing it as a result of the upgrade
Please just sit tight and a resolution will come as soon as feasibly possible.
Thankyou.
  • Replies 55
Posted Images
I'm trying to upload pics to one a post and it wont allow me, I receive the following error:
"Upload failed. Please ask the administrator to check the settings and permissions"
The pics are only 41kb in size and I've tried two different pictures. Neither of them work. I have tried a new post and it also doesn't work.
Please help!
Thanks.
Thanks Sl!m, I started reading that thread but the initial posts had nothing to do with my problem. I didn't realise it was a post full of unrelated faults until you pointed me back at it.
i keep getting this message and i can't post pics up.((( Upload failed. Please ask the administrator to check the settings and permissions))) why!!!!
this is happening to me in the for sale area and everywhere on the sau site when it comes to posting pics
I was able to upload a few attachments a day or so ago just before the last server maintenance but tried again this morning and got this error message.
Upload failed. Please ask the administrator to ensure the uploads directory is available
i have a for sale thread trying to sell my car but can not upload any pics of it.
i have tried on several occassions and its really pissing me off.
noone wants to look at a car that there is no pictures of.
is anyone else suffering from the same thing i am???
Attaching images works for me...
Loading time will be fixed soon, I have to run the site for a while on a new server to accumulate enough logs to base the changes on.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
