OK guys I know how sacrificial and immorale this may sound but I just can't help it,
I wake up in a cold sweat everynight even thinking about how wrong it must be
But I loooooove the BMW wheels in the pic and was wondering if a photoshop expert could please photoshop them somehow onto my ride.... i just think they would look sweet of i got rid of the BMW badge..........
If someone could help me with this would be much appreciated....
Below is the pic of my car and the wheels that i just can't stop thinking about, i currently have 17's and would like to put the BMW look alike 18's on.....
photoshoppers ....please help....
they kinda remind of the do luck double six but with a few extra spokes....
anyone know if they would they fit a r33 gtst?
https://www.sau.com.au/forums/topic/66310-need-help-bmw-wheel-on-33-gtst/
GTshortie and 51jay are 100% correct.
I have a BMW, and I have a GTR.
BMW is 5x120 PCD
Nissan is 5x114.3 PCD
They won't even slide onto the hubs because the hub bolts are in different spots. Just because they have 5 holes in them, doesn't mean they're the same.
And you're completely forgetting about offset too. BMW E46s use a +40mm offset front and rear and won't be right for your R33 GTS-t.
BMW is 5x120 PCD
blah blah blah
DO IT!!!!!
im sure its possible :)
AHAHAH thanks silver gtst for your suppport...
I may have to listen to the feedback and see what can be done, have seen some wheels with exra holes drillled in them to make em fit...Hmmm but i really dont think so if the offset is out 40mm...
Just wish i could find a way.....
You can get hub spacer’s machined up to suit that stud pattern. Like the 4 to 5 stud bolt on hubs, thus bolting onto your 4 studs and the spacer having 5 studs. As you already have 5 studs, I can’t see why you couldn’t get them machined up, but have the new stud pattern made to be 5x120.
These wouldn’t be an off the self-item, and would be custom made of course. Then you have to deal with the BMW off set being wrong…
Work out easier getting rims to suit a Skyline in opinion. But hey be different, could be interesting.
Am talking to a metal engineer friend of mine on Tuesday about seeing what can be done with the wheels as we have a public holiday on Monday (YAY!)
Too scared to think how much it would cost but will soon find out!
anyone managed to do a bit of photoshopping for me??
BMW is 5x120 PCD
hahaha too funny there is so many different types of 5 stud oem wheels available
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
