went to a mates fair well last night at one of the biggest gayest bar wig and pen, very good beer but (oh the thought of beer atm yuck)
any ways left there continued to drink at every bar in civic well almost, got to north bar and walked to the toliets to find 2 chicks getting it on and rubbing each others tits under there shirts. All for this guys undies they then proceded to hit me up (3 of them this time oh yeah) buy the time I had thought of something (was very drunk and wanted them to do something good) they all left. Must have been for a hens night. Just thought I would share.
https://www.sau.com.au/forums/topic/66439-last-nights-events/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
