well i have an R32 GTR and i want to try and find a set of brembo callipars to fit any ideas where to start looking, or should the original callipars be fine. i think the v-spec came out with them but otherwise i need them from a later model. does any one know it they fit straight on or will some changes need to be made?
https://www.sau.com.au/forums/topic/66515-r32-brembos/
Yeah I would be looking at other options, to me the brembos are expensive for their size. Have a look for used 6 piston ones instead if you reallyh need bigger brakes.
But you probably dont need bigger ones, jus get good brakes and great fluid
https://www.sau.com.au/forums/topic/66515-r32-brembos/#findComment-1239694
Unless you are doing regular track days they expensive rice but having said that I can get you some reconditioned for about $2500
no offence to whoever your supplier is, but that is exactly why people should not buy GTR brembos.
I paid $1500 for mine and it hurt, but I had no choice due to racing class rules.
For $2500 you can get the 6 spot porsche brembos on the same disc as the gtr brembos.
https://www.sau.com.au/forums/topic/66515-r32-brembos/#findComment-1241459
2,5k, i agree is a rip.
The 6-spotter Porka Brembo's retail @ ~$800 per calliper. And they are double the size of the GTR brembo, and piston size is very large
So thats $1600... plus fitting and a two piece rotor and your around 2.5/2.7k which is far better value if your spending that much
https://www.sau.com.au/forums/topic/66515-r32-brembos/#findComment-1243613
Ok a question concerning the 6 piston calipers though.:D
The pistons are different sizes front to rear, correct:)
The pistons are sized this way so that when travelling forward the pad is forced evenly onto the the rotor.
Now if i look at a Porsche, the brake caliper is on the rear (door side) of the rotor with bleed nipples obviously facing upwards.
So now if you want to put the same 6 pot Porsche caliper on a Nissan, the staged pistons sizes are going to be the wrong way around, as you will need to swap the LHS & RHS side calipers so that you can bleed them correctly.
OR, is it a matter of swapping the bleed lines and fluid line around so that it all works?
That plus talking to places the axial mount on the POrsche 6 pot caliper makes them a pain in the ass to mount on anything but a Porsche:( it can be done like anything, but i still need some convincing that this avenue is the way to go?!?!?!?!?!
https://www.sau.com.au/forums/topic/66515-r32-brembos/#findComment-1267034
Where can I get my hands on these 6 pot Porsche Calipers? Can anyone point me in the direction of who might sell them?
PM me please!
Any advice appreciated!
get out your yellow pages
And right your nearest Porsche Dealiership.
If not, ring interstate. You wont be able to get em anywhere else
https://www.sau.com.au/forums/topic/66515-r32-brembos/#findComment-1267285
And one more thing. From a bit of reading i have been doing of late...am i right in saying that typically you can use a good qulaity 4 pot caliper up to 355mm in rotor diameter, but typically 343mm is seen as the biggest rotor you run with a 4 pot caliper?
Any bigger and the caliper pistons are nto in the ideal position relative to the rotor and their ability to force the pad onto the rotor is compromised. So typically if you want to go bigger then a 343mm rotor then you need to start looking at 6 piston calipers?!?!
And vice versa, if you have a 324mm rotor, then most 6 piston calipers wont saddle the rotor properly and the the pad contact patch wont be quite right?!?!
Is this correct? As a rule of when you need to consider calipers, its more a rotor diameter thing then wanting to stop any better?
https://www.sau.com.au/forums/topic/66515-r32-brembos/#findComment-1267474
  • 3 weeks later...
I checked out some 6 pot Porka calipers today. On a Skyline the pistons are going to be around the wron way.
Porsche have them so that the small pistons lead, with trailing larger diam pistons. So the only way to orientate them on a Skyline so that the pistns can do their thing and maxise pad wear/force is to swap the fluid/bleed lines around...but i was not able to confirm whether the internal galleries are symmetrical and this can be easily done.
It appears the Posche 6 pots wont work properly, so looking at a CSC 343mm setup next week, escaping that i may have to go to 6 pot APs as the 4 pot APs dont take a 32m thick rotor, only 28mm thick :)
https://www.sau.com.au/forums/topic/66515-r32-brembos/#findComment-1293767
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
