Hey guys,
I have recently acquired a $200 credit from a performance parts store and wondering what to get for my brothers' R32 GTS-T... I owe him big time so this is something small I can do for him.
He's already got a HKS panel filter (foamy one... looks old), springs, shocks and a strut brace.
I was thinking either:
a) APEXi Power Intake Pod Filter (if its not a pain to fit) or a different panel filter. Any suggestions?
B) BOV. Do you need a special adapter for them?
I don't have any extra money to put towards something more expensive so anything you can sugges for under $200 would be much appreciated.
Thanks for any help in advance.
His panel filter is a foamy HKS one apparantly one that is meant to be replaced - not cleaned etc.
He would like a bov... was talking about it not long ago. I think he wants a venting one but then again he doesn't want anything TOO loud... I suggested a GFB Plumb-back but he said it would be a waste as there's already a p.b on there lol... its still the factory Nissan item but wouldn't the GFB be better?
Then again if he wants a venting one I suppose it's up to him :)
I think i'm going to get him the APEXi Power Intake Kit... Any ideas for a decent cold air feed? I think he's got a pipe running from the fog light arear up to the current airbox inlet.
Any other suggestions or items out there in the way of heat sheilds or the likes?
a GFB bleed valve is just under $40 trade price, and that's not a ball and spring type.
for quick wank factor and if your brother likes the flutter noise, get him a BOV.
But for the gift that keeps on giving, get him a Cold Air Intake.
Hey shannon :) Brett here. hows that pulsar going
Just off the top of my head a few other cheapish ideas could be window tinting? apexi pen style turbo timer they are pretty cheap like $50 I think, clear indicator lights, gear knob? boost guage if he doesnt already have one?
new pod filter is a good idea too though, the apexi and K&N ones are prob best, apexi has real good airflow and still filters real well too.
let us know if you need any help
go for a decent pod filter, they should be easy to install. just get one for an r32 gtst and it'll come with all the bits and pieces you need, and probaly a badly translated instruction booklet.
Bleed valves are a bad idea, he should have an exhaust before he starts upping the boost.
or just get him a nice looking boost gauge or something else interior wise (maybe a steering wheel or something)
it really depends on what this shop has.
Thanks for the help guys... well those that made REAL suggestions anyway.
It's not a physical voucher... it's just that I have credit at a parts distributor (or what have you).
He's already got a steering wheel and it's just recently been serviced i think so all is well on that front.
I was thinking about a turbo timer but then again... how hard is it to wait a minute or so before turning your car off?
I'm just going to get the APEXi P.I Kit and we'll sort out some kind of heat sheilding.
Thanks again for the help.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
