  • Replies 52
I think you might be lucky.. as it's a day's work, if you know what you are doing, probably 2 if not. It's not something you'd choose to do for 'fun'.
I think v8man is pretty much ob the ball with the list of parts, as I'm just in the process of collecting them myself. He did miss tailshaft though, which is an important one (I paid $150 for my manual shaft)
ECU does not have to be changed, but thats been covered. Auto in manual req eCU change, manual into auto not. It will work anyhow, if there are any issues, change it later.
There is some basic wiring you have to do too with neutral switch and a few other things. I don't think you have to change the cluster.. maybe on R33 as it has the christmas tree auto thing in there. but R32 they are exact same (I have two clusters sitting around).
You will need to change your speedo sender too, for the different ratios - or your speedo will be out.
Does anybody know where you can get the selector fork from and boot? From memory it looks very similar to R31 one (nearly identical sized box).. but i didn't get one with my box :P
For R33 boys you're looking at about $2000 in parts, so it won't be cheap.. There is no place that sells the kits "complete" afaik so you'll have to hunt for a halfcut, wreck, or a wrecker (who will charge you big bickies).
Already for my cheap ass box, and rest of the bits on the R32, it's going to be up around the $1000 mark for the bits.
wasnt aware tailshaft was different....but i was ready for it as a lot of times they are...
catch can ....i can to that tomorrow arv i suppose.....after 4....50 bux it'll cost ya....
i hope you have all the bolts for it...other wise ill have to look thru my box of bolt and i cant guarantee ill have the right ones....
yeah i guess....off the top of my head you will also need hose clamps,,,,,,rather than wast you time...you should come round so i can check it out first, uncase there is more stuff you need to get.....that way it will be straight forward when i do it...
STZ automotive in Northgate are pretty good and they have extensive experience on skylines.
i don't have the number on me at the moment but its in the white pages too.
they are in Landy St Northgate.
they did my silvia rb20det conversion + manual conversion and a few other goodies.
How much was the conversion?
the R32 half cut = $2000
hybrid copy intercooler + piping $530
SR20 front brakes = $100
complete workshop charge (engine, wiring, exhaust hooking up, front brake change, intercooler mounting + manual conversion included) = $1500 - 1600
i get the car back anyday now, (closed for easter)
  • 14 years later...
On 15/03/2005 at 8:35 AM, V8skylineMAN said:
if you have ALL the required parts im sure i could do the job for you. a lot cheaper that a workshop...but dont get me wrong it'll still cost ya
Hey man I have a 2008 ford falcon bf I was wondering if you would be able to convert it into manual from auto, I live in Brisbane btw
Hey man I
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
