  • Replies 106
Posted Images
I lighten them in game. I play with the contrast alittle in PS as well as a little blur here and there.. and with the level feature. Some of the shots have multiple layers. and some of them have been polished alittle cause of the pixel that show up in the shots... I tryed to smooth out a few of the rough edges..
I like your shots, maybe its my screen but they seem fine to me, not too dark at all.
check some of the shots out here. They even have some photomode comps going. If you have a look at the hall of fame section, you'll see my xr8 shot in there. :P
Heaps better Topaz... I like the 4 bottom row shots especially.
Just another hint though, when you've taken the shot and go to save it, always select save straight to flash memory stick (as when you save to memory card and then copy across later to memory stick, it pixilates a tad).
also there is an option to select "super fine" image quality. That will also help remove a few pixels....
But I love the angles and the shots are heaps better with a tad bit more light in them
oh, I thought they were a bit pixelated.... :blink:
I do have Super Fine selected and I do save straight to my USB key
I tend to pic a random 'line' in the image rather than the horizon to match with the edges :)
Whats the motion effect called in PS that you have on that R31 above?
cheers :)
Did a little photoshooting tonight...
EVO BATTLE!
Can the Evo 6 beat the Evo 8 MR on the tight and twisty Amalfi Coast course?
The Evo 8 starts off in the lead and hugs the corners...
A little bump at high speeds = big jump.
The Evo 8 holds off the Evo 6 and remains in the lead through the tight roads
The Evo 8 hits a street kerb and sparks fly!
The hard stopping puts a strain on the brakes as well as the front bumper!
The Evo 6 tries a bold inside move!
Can't help admire the scenery...
Hope you enjoyed the pics! :)
more pics..
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
