Hi there guys, just trying to find myself a new replacement set of bulbs or just bulb for my r32.
The bulb is H3C is that right?
Any suggestions/reccommendations would be appreciated. I tried that little 'car accessories' shop in carousel, they said they ran out.
Anyways, cheers.
I had success with my bolbs at Carquest in East Perth, Shop 9 Piccadilly Square, 5 Short St. They have website but you prob wont find the bolbs listed on there www.carquest.com.au
I'd go in there, I hunted everywhere and found most of the stuff there.
Ciao!
Im pretty sure mine are not H4 (r32 gtr), as ive tried those and its a total different design, my mechanic said they were H3C - i think he said they were same as s13 sil, not 100% sure but its def not H4 for mine.
Most places i found dont stock the H3C.
Thanks every one for your help, cheers.
When trying to find parts for an import ure best bet is to ripp it out and take it in and match it up with what ever they have, usually they have some crazy ass number on the side that gets you nowhere but the part is exactly the same as a standard part from a commo or something. just a bit of advice coming from the guy who get weird looks when he says
Me- "its a nissan auster"
Repco/any car guy- "Nissan what?!?!?!"
My right hand indicator bulb has blown twice in two months :D
Stop overtaking people so much, then you wont need to use your right indicator so much (haha)
speaking of blown bulbs, my ute has chewed 3 LHS bulbs in a month....sus, must be something im doing wrong
hey speaking of bulbs? i have a gtst, its has park light, projector and high light in one cluster (like gtr) but are those bulbs (main light, projector) H1 or H3C cos i am trying to find white/blue lights for my line? any advice anyone?
Pretty sure it would be h3c, but i could be wrong, the H3C just has 2 big prongs on the bottom, just do what the others said and rip one out and take them out and about.
As for blue/white in H3C - i found them virtually impossible to find in Perth, maybe some where east has them readily available not quite sure, i found them hard enough to find 'normal' globes in the H3C pattern.
if you really want the blue/white look, id personally go a HID conversion, theres a bloke in the Forsale/parts section selling them for about 350-400 i think. Id pick up a set straight away, if i didnt have to buy so many uni books this semester :P
neways, good luck :)
  • 4 weeks later...
ok, i was looking at ebay, is there any difference between H3 and H3C? just want confirmation cos they do sell blue/white lights in both these codes..
Yep, they are different - take a look at www.narva.com.au/Globes_16.html and you will see the difference.
The main difference is that H3 has one prong, whereas H3C has two prongs (positive and ground).
My r32 has H3C bulbs in them aswell, but i was told that you can put in H3 and just attach it using the positive side of your plug. In saying this, does it mean that the H3 (and the H1 for that matter) doesn't need a ground wire since they only have 1 attachment?
Most companies only stock the standard light colour for the H3C, whereas you can get blue, white, arctic blue etc in the H3.
Anyone tried replacing the bulbs like this?
Just replaced my H3C bulbs with H3 bulbs...
Since the h3c bulb has 2 connectors and the h3 has 1, all you need to do is solder a piece of wire to the metal base of the h3 bulb and attach it to the ground wire in your headlight loom. The other wire just plugs into the positive side.
**The headlights that normally use h3 bulbs are already grounded hence no need for an extra wire.**
Works perfectly. :(
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
