  • Replies 101
I'm doing the same conversion into my 32. I've got the bottom end all ready to go. The biggest problem Ive had so far is finding a rb25 n/a head without (vvt) I try'd out the 33 head but their is way to much work in modifying the water/oil gailrys on the head.(oil activates the vvt set up). Not to mention the wireing involved. Still trying to figger it out.
1. Anyone know where I can get a 32 rb25 from?
2.The Dayco Timing belt is $90 from autobarn.
  I can get them for $60 if anyone's interested.
  ( 0403541636 )
i think you can just use the series one RB25 head off the R33 which doesn't have VVT, some please correct me if i'm wrong or you could also use the GTR head which doesn't have VVT but i think they go for a lot more than RB25 heads (anyone clarify prices for these?) RB26 Head!
I would also recommend if this is on a budget, dont forget the hidden estras with the build, which can quickly blowout costs....from your list above lets say :
1. rebuilt rb30e bottom end rebuilt with std pistons etc - $1000 (including purchase)
2. rb25de head $750
3. An Rb20det AP Power FC can be gotton for cheap second hand...Cubes got his with HC for $1100 ish....wiring up a rb25 loom adds say $600 on the price of the purchase of the loom + rb25det computer etc.....
4. timing belt - $30
5. extra pulley (tensioner rb30e bearing) - $80
6. Rb20det gearbox - u got one...see how long it lasts...ud be suprised
7.rb20 turbo...$0 (Garrett GT35r will cost $1850 odd + manifold + ext. wastegate)
8. Extreme clutch - i had one with the rb20, now the os twin i got i run in mine feels better on the street than the extreme....
9. Rb25de lower half of inlet, rb20det upper half (with throttle body), rb20 exhaust manifold.
10. rb20det sump
11. rx7 injectors (dont need a regulator if you upgrade the fuel pump instead....have you yet?) say....$500 + $350 for pump
12. Head gasket - cheaper to buy a VRS kit for the rb25de head - $cant remember...lol...
13. oil pump - rb20det, water pump - rb30e ($80)
14. Bearings - take your pick ....ACL, King, etc......dunno cost
15. Q45 afm - $300
Thats roughly just over $4000 (not including everything above)
If you are not doing the work yourself, add installation labour, tuning....you will be close to $10,000 before you "finish" (read bigger turbo) with it.....
Any hassles come up (mine for instance wouldnt idle straight away, needed a bigger fuel pump + injectors, and needed a tune)
It can be a budget motor, but only if you do most of the work yourself. Dont let me put you off, but think seriously of doing this before spending.....
I have upgraded the fuel pump to a GTR item!
All R33's have VCT. The extra work in making VCT work is minimal. Run an external feed from the oil pressure sensor to the VCT oil gallery. Block off the original feed in the head then have a welder add some material to the head to match up the coolant galleries and surface it. It's not rocket science! Any machine shop can manage this.
Yeah rb26head is about 2k...minimum.....3k closer to the mark.
There is a RB25 non vtec head going in the forsale section for like 200 or sometihng similar atm (need valve springs i think, good idea to replace em anyway) its at top of the classified in a sticky tread donation sale
6 x 270cc injectors at stock fuel pressure at 100% duty cycle should flow enough for ROUGHLY 324hp at the engine. (27x2)x6) = 324
that is ROUGHLY 226kw at the engine (I think)
that is ROUGHLY 181rwkw (if you say 20% loss to the rears....)
are my calcs wrong?
I know for a fact that just an upgraded fuel pump does not increase the pressure (at least my walbro one didn't over the stock S14 item)
someone help me out here..
how can 270cc injectors be pushed to produce 240rwkw at 70% duty cycle with the regulator.
I understand that an increase in fuel pressure will in a way make the injectors flow more than 270cc but THAT much more?
I'm kinda happy that this is so.. saves me buying injectors at the begining.. but I want to see others thoughts.
very helpful, as always sydneykid, one more question for now, putting this in an R32 u need to drop the motor round 15mm, just wondering doesn't this cause the gearbox to no longer line up? and exhaust etc?
Won't cause any problems that I have seen. The tailshaft uni joints are on angles, a little more won't matter.
The exhaust is not solid mounted.. so that won't be affected.
I have my RB30 mounted in my S13 with it lowered 15mm, and I just fitted an RB26DETT box that I have modified. I will be running a one piece tailshaft. All fits quite nice considering.. (only a little hammering :( )
GTST:-
What you can calculate on paper doesnt always turn out that way in the real world.
The increased fuel pressure makes the injectors flow a fair bit more.
All i can say is ive done it with 2 of my own cars, a few mates also run good power with stock injectors, so ive seen it work many times.
Why not give it a try.
I have my RB30 mounted in my S13 with it lowered 15mm, and I just fitted an RB26DETT box that I have modified. I will be running a one piece tailshaft. All fits quite nice considering.. (only a little hammering :D )
thats what i wanted to hear, this is all very helpful and thanks to everyone once again, now to go checkout this head!
mr_rbman,
For engine mounts head down the Shaun at Boostworx.
I bought my R32 RB25 head 2yrs ago from Adelaide jap for $750.
Take what Adelaide Jap say with a pinch of salt as they really don't know what parts are from what car.
They claimed my RB25 head was a R33 RB25 as the R32's didn't have a RB25 lol.
This was 2yrs ago so they may be a little more informed these days. :D
Wait till you get to the gates of heaven ... you R32 owners running Rb25s and RB30s.
God himself is upset by this conversion, and will no doubt send you straight to hell for this heinous crime :flamed:
lol, but we just wont to go fast and will do it anyway possible, all i know is 350rwkw rb25 is alot faster than the old 230rwkw rb20, just a pitty it costs a few $$$
Roy... What power are you making?
How much have you spent not including all the fires and buggers ups? Just the setup. :)
How much have I spent.. ummm 7.5k and counting. :D
How much power?? lol.. Bugger all. More money needs to be spent to get the bigger turbo on.
I'm going to book it in for a tune in a week or two. I've sorted out the fueling. :D
I am very interested what the stock turbo can do on 11psi.
At the moment @ 11psi knock levels are around 20, rolling on in second gear lights the rears up from 2200rpm and flicks the tacho to 6000rpm, it seems to rev just as good as the rb20 but holds you in the seat much harder, especially in 4th and 5th. :D
I can see traction problems becoming stressfull. :D
LOL..stir the hornets nest:)
Ok if i had my time again...These are the prices i picked my gear up for.
HKS Type S Intercooler - $1150 (Combo of my own piping and HKS piping)
Apexi Power Fc c/w hand controller (tuned with ) - $2,300
Z32 AFM - $300
Trust TD06-20G with manifold and wastegate, injectors and some lines & piping $3,300
Clutch and flywheel - $1200
AVCR - $650
What came with the car;
- HKS Air Filter - $300
- HKS 3" exhaust - $1300
At 22psi it made somewhere around 250-260rwkws, at 17-18psi it makes 235rwkws for an average power of 208rwkws between 4,000-7,000rpm (Perhaps around 215rwkws if i bump up the rev limit)
So realistically to get 235rwkws out of my RB20 it cost me $9,000 all up including labour
Throw in the dead engine that got warrantied ($600) and the fire ($400) and it comes in under 10k.
Problem is there was a 3 month window when a mechanic was working on the car instead of me and friends and that soon added close to 5k to the bill with nothing to show other then other problems. It was just one of those things:(
Sh1t, im so depressed now.:D Its a lot of money to get so little power, i mean POWAH. But if i could be farked i have priced an RB30DET for about $6,500, thats with cams, pistons and rods. $7,000 with a bit of porting
Then i would need to get my TD06 rebuilt and hi-flowed using either a 25G compressor or a GT30 wheel (and back to 10cm exhaust housing) About $1400..RB25 gearbox and twin plate clutch with modded tailshaft. $3100
So to go from 235rwkws to 335-350rwkws it will cost another $11,000:(
It would be great and so envious of you boys doing it, i really am. But i just cant bring myself to spend that sort of money, right now its not what i want to be doing with what little money i have, and id rather spend the money on going to the track to enjoy the pea shooter:)
LOLO...i thought id just make a nuisance of myself and pigeon on about RB20s:)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
