Hi Guys,
I am from VIC and looking at purchasing something from a QLD member.
The members name is Genesis.
Just want to know if people know him, dealt with him or will vouch for him.
No offence at all intended toward the member and I apoligise if this post is out of line or if you are offended.
Just been a few scams lately and I have never purchased interstate before and a bit nervous.
Thanks guys
Jayson.
https://www.sau.com.au/forums/topic/67706-trading-with-a-qlder/
Dont know him personally... you could always have a Queenslander pick it up and send it too you if you know anyone up here, if your worried write an agreement of sale stating said condition, get it signed (fax) and COD it.
haha... glenn = floated on a bag of rice = .......
Well now that everyone knows - he'll have to go through with it wont he :)
Glenn is a good guy... no probs..
P.S. he likes it downlow style... *thats what milo says anyway*
qld's are ok to deal with..... im in SA and im buying some stuff of off Skid( qld Member), he's keeping in contact and letting me know whats going on.... i was worried about it at first... but skid is keepin me pretty chilled about dealing with interstaters..... so i wouldnt worry too much.... if things go wrong..... KARMA.... will get them!
Glenn is like all high level sinaporian asian gangstas, mess with him and hell go and have a cry, then he'll go look at his empty engine bay and cry even louder :cheers:
In all seriousness, he is a great guy, I want to have his babies.......
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
