It should come with eight of everything.
I asked for the sj6070 kit but they said there was no stock but they had the protex kit in over night.
I paid $54 including inward freight plus postage to me. It came as a kit for one caliper but they sent me a second kit no charge as they quoted it as axle set.
  • 4 weeks later...
  • Replies 49
i just got quoted $50 for the seal kit (the book said thats for an axle set)...
but the guy said i'd be up for about $340 to have to front calipers overhauled by them!!!
he said 1.5hrs labour PER CALIPER!!! :D
i dont think i'll be goin back there
  • 4 months later...
Ah, after some phoning around this morning it seems that the ABS system shows 0 stock and 0 on backorder of SJ6070, and no linkings to 210E0011, which is definately the superceded part number. ABS in Melb quoted me $40 for the kits, but wernt sure that it was an axle set, or just a single.
Lucien, is the set an axle set or just a single one?
  • 3 weeks later...
I just rang Perth Brake Parts, who didn't have a listing for my car (R32 GTR) and told me I would need to remove the calipers and take to them to be measured up so they could find an equivalent. As I only have one car and I kinda need to drive it wherever it needs to go to be seen to, this isn't really an option for me....
So I rang my local Nissan dealership, who want $247.10 for a kit to do the rear calipers, which consists of RUBBER ONLY. This is absolutely ludicrous!!
I read through most of this thread but couldn't work out whether you guys were talking about R32 GTR's using the same kits as a Z32, or R32 GTS-t's??
If someone could clarify or PM me the info I need it would be greatly appreciated....I'm getting nowhere fast here. I have a leaking caliper, and a motorsport event on next week that I have already paid for.... :D I am located in WA but I don't care if I have to get something sent over from NSW or Vic....
  • 3 weeks later...
To consolidate a few posts:
SJ6024 is an axle kit
210E0011 is a single caliper kit (just found out the hard way)
Not sure about SJ6070
As R32 GTR calipers are apparently the same as R33 GTSt calipers, the part numbers should be the same.
@Fiona: If you're still looking for the kits, shoot a pm over and I'll order some from over east, sounds like it's a lot cheaper. That is, if you haven't sorted it already.
The wheels are now off the car. The Metalcast paint is waiting to be picked up from the auto shop and I'm hoping they also have a 36mm socket with a 1/2in drive! And a piece of lead pipe to extend my breaker bar!
I'll report back on Sunday night with how things went over the weekend.
Ok. Rotors have been fitted. Calipers have been painted and overhauled. The overhaul sounds more exciting that it really is. They should rename it to "replacement of rubber seals and a good wipe down".
Calipers have been painted and refitted. Pads refitted. Brakes bled. Wheels on. Took it for a drive...
Back to school, brakes need a pump before they have enough pressure to operate properly. Thinking things through I think I may have removed the bleeder hose before locking the nipple on one of the calipers. Damn.
Anyway, the braking that I did do was such a huge improvement, I am looking forward to rebleeding tomorrow night and trying again.
Oh yeah, bent the socket rod using the water pipe trying to crack the 19mm bolts at the front :angry: Wasn't a cheap set either. Grrr.
Mark
You may find the last 1 or two air bubbles work their way to the top after a short drive. Give them a little bit to work properly. I always have the same thing happen. Just check the reservior after and top it up. It needs a good few brakes to work 100%
Bled them again the other night. No need to pump anymore, yay, but it is still a little spongy and you can't heel-toe anymore.
Thanks Black32, I've driven it for 100km or so, so I'll have another go as soon as I can build up the motivation! :(
Any RB74s are squeak free! :( CRC Anti-Squeal Paste then bed in as instructed by Racebrakes and haven't heard a peep, hurrah! The ABS works too!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
