Was driving home last night and every time after pulling up at lights the car would surge momentarily when accelerating away. Whatever was causing this, it must have got worse because a couple of blocks from home I couldnt get above 2500 rpm. The more I put my foot down, the less power the engine had.
It felt similar to fuel starvation however after popping the bonnet I noticed there was no pressure in the radiator hoses. The overflow tank was mostly full so I had not lost a lot of water. I am going to give it a throrough checkup after work today but could this be a ceased shaft turbo and blown water seals. Stock turbo at 75,000 km. I already have a spare fuel pump ready to go as these are renown for blowing up but I am still confused by the lack of water pressure.
https://www.sau.com.au/forums/topic/68065-help-no-power-after-2500-rpm/
I think the ECU has a limp mode, from what i've heard this stops the engine from reving over 2500, this could possibly be what's happening to you.
As for why it could be in limp mode, i'm not sure what causes it but i would guess overheating would be one main reason, faulty sensors could be another.
Did you notice if your radiator was hot or not? If the radiator doesn't get hot but the engine does you're car could be suffering from a busted water pump.
Could be anything mate, I'm just throwing ideas out there
Good point, will check the AFM. Not sure about limp mode as the car has a Power FC which I forgot to mention. IT s not a hard 2500 rpm limit, just feels like fuel starvation at anything above this.
The PFC lets me see all the engine instruments from the display. The water temp was only 95 deg C, and I recall the AFM seemed to be producing a sensible reading when revving up and down.
It doesnt know the A/F ratio which would be handy.
I am going to have a closer look tonight to see if I can hear the turbo spooling and some sort of boost being made and post back tommorrow.
ive got the intercooler prob also. its got a leak and does what youre saying at around 3000rpm (where it hits about 0.5bar). before it would be at 0.9bar at 3000rpm, but not it gets there and just dies, constant 0.5bar reading, and no power at all. with all the windows open i can hear the leaking of air, and the bov also sounds slightly different in a funny kinda way. but yeh, im got boost leak, which if i were to describe would sound very similar to what you are saying..
something that could help, if i dont have the accelerator down quite as much, it will tend to act 'normal' again, and continue to rev through the range until it is creating too much boost, then i ease of the accel a bit more and it will continue to rev another 500rpm til doing the same thing.
as long as i dont create too much boost (in which case air would be leaking while too much fuel is being put in.. im guessing..) and keep it around 0.3bar by lifting off the accel when it gets too much, it will keep on reving. easy to do between 2000 and 3500rpm, but the higher the rpm's, the easier it is to create boost and more precise i need to be with the accel pedal as to not give it too much exhaust gases to spin the turbo thus create boost.
i hope this dribble helps somehow :D just sharing my expreience..
shaun.
Okay,
Thanks for all the input so far. I made some more checks last night. Just idling in the gargage I can sometimes get the engine above 2500 rpm by letting it idle for a while but it still seems to be lacking pickup and power at all rpm's. Sometimes it will rev over 2500 rpm and then other times it wont, theres no rhyme or reason. All engine sensors appear to be behaving sensibly according to my power FC hand held. ie Air flow, air/fuel ratio, timing, rpm, water temp, voltage, injector output and boost pressure.
All intercooler pipe connections seem to be sound as far as I can tell and there is no sound of air escaping. Water temp is okay it did not exceed 90 deg C.
Turbo appears to be okay or at least I can hear it spooling and there is no exhaust coming from the radiator cap or water from the exhaust so I think the seals are okay. The problem starts from a cold engine so problem is not engine heat related.
Idle is very smooth but then the missing (or lack of power) at higher revs appears to be all cyclinders at once so this seems to point to either fuel supply or complete ignition breakdown.
The spark plugs are at least 10,000km old so I will change them tonight, not being really sure how long to expect in an RB25. If that doesnt fix it I will change the fuel pump over to the Bosch 044 I have waiting. Failing, that I'm thinking an electrical breakdown to the coils and something for a workshop to sort.
Cheers for all the help.
Hey,
Have received my 32 GTR from japan in last fortnight and have this exact problem. Did not seem to have it when i first got it, but has pretty bad now. Seems to be a totally random thing. SOmetimes drives sweet then does it, other times does it as soon as i start the car, comes and goes all the time. I have found that if, when it does it, I get out and jiggle the wires on the top AFM the idle will cahnge and is now sweet again, only to come back again. Have had both airflow meters run througha diagnostic with no evident problems. Will be getting some spares to test with soon. If you have any luck pls post as i would love to fix this also.
check the airflow meter setting in hte powerfc hand controller.
If you set the setting to something other than what you have, it will cough and splutter when trying to rev after 2500rpm, and stall when the revs come back down. You will also blow alot of black smoke.
I know this because my mate ****ed around with the powerfc setting and chaged the afm type.
Had me stumped until I had a look.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
