I dunno, as much as I feel that you should get some reward for this work, it is still copyrighted material, so charging for it might not be a good idea.
  • Replies 42
I agree with Shan: I don't think charging for it would be appropriate. As long as people get some use out of it, I'm happy.
I have almost finished the first 300 pages. Its taking about a day per 50-100 pages, so hopefully by the end of the week I will have a 'first draft' done. It will need some editing to make it pretty again, but that's a lot easier.
Lucien.
Lucien.
Very nice work i have been looking for a copy for ages let us know when u get the new one up please....
AWSOME JUST AWSOME
Duncan: so I take it you would find search-ability useful?
LW.
absolutely brilliant.
we use it all the time, paper and electronic copy, and it is a really poor manual.
Compared to other workshop manuals it is really light on (yes at 800 pages still not long enough) and poorly laid out.
The second point is what pisses me off, and why searchability would be great. Today's example.....clutch bolt torque and flywheel bolt torque are a good 300 pages apart :)
Up to about page 330 now: hopefully finish tonight at about 350-ish. Doing about 50 pages a day at the moment, but that might slow a bit over the week as I have other commitments.
Duncan: Good-o.
There will still be a few problems with searchability:
1) I am doing most of the tables of data as images because their layout gets screwed otherwise. However, the headings for the tables are text. When/if I have time, I might go back and redo the tables as text (but its a fiddly job).
2) If paragraphs include images -- like "1" or "A" within a circle -- I have to do that paragraph as an image because there is no other way to preserve the special characters.
Most everything else (except, obviously, for the pictures/diagrams) will be searchable.
Lucien.
Euncan... i've got the japanese service manual, and its a lot more comprehensive... albeit in a different language. However the diagrams and charts are fairly easy to follow and if you have a english manual to backreference it to, it should make it a LOT easier to use... I'll bring a copy to sydney when I come up for the weekend, and if you want a copy feel free to grab a copy off me then.
  • 1 month later...
Just so people know, I haven't forgotten about this: I have just been so busy of late I haven't had time to even look at it, so I am still only half way through. In about a months time I hope to have a little more time to devote to it. Have faith, I will get it done eventually :(
Lucien.
  • 4 months later...
I found that Acrobat 7.0 pro works great for OCR, it went throught the service manual in about 10 mins, and set it all up. If you have somewhere to host it I can upload it for you.
sav man: Yeah, I noticed the OCR facility in Acrobat 7. It seems quite good though I haven't checked how it deals with some of the funkier formating. I still intend to finish the OCR'ing of the workshop manual the way I was doing it as I am slowly cleaning the pages up too. I've got about 7 weeks till my thesis is due and then I should have a lot more time :D
nxtime: I would always encourage people to donate to SAU or join the club(s). Given the grey area that exists around the manual I'm not sure requiring people to pay would be a good idea.
homerz: Its bound to be exactly the same one.
  • 2 years later...
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
