drivers side seatbealt,mine dont wind back up, ill give ya $5?
where in sydney?
n ill take ur headlight globes(unless already sold)
n that black plastic under the engine that protects it from rocks on the road.
n the 2 windscreens squirters on ur bonnet(theings that shoot water at ur windscreen,mines blocked)
0410531540 anytime between 9am n 5pm.
  • Replies 77
  • 1 month later...
i'm after the rear boot lid, steering wheel...
how much? and wats the condition of the steering wheel.. if u got pics email me..
$60 each? but feel free to give me a counter.. pm me
edit: dont need the bootlid anymore.. still after steering wheel
Judd, I want the bumper call me on 0401 896 663 or PM me. I also want the interior piece that runs up the drivers A-pillar (where you would normally put a boost guage) I will give you $25 for it. I live in Sydney and will collect these from you on Saturday.
WOuld you be interested in selling the metal impact bar that sits behind the front bar?? If so... how much?
Also, my CV joints are on their way out so i was wondering if you would be keen on selling yours (if they are in good cond). If so, how much. I need both sides.
I also need to get hold of the following seals; * drivers side door seal
* Front windscreen seal
* Rear windscreen seal.
Are they in good cond???? Make a price.
Cheers,
Scott.
Hey buddy do you have a R32 steering,very interested, tell me if you do.
Cheers
JD
the lot must go..
big plans, no money.
RARE
late model 93.
Engine + turbz (77,000km)
gearbox + new clutch
interior (no rips no tears)
dash
thats the big stuff taking offers on the lot
5% of the sale of every item goes to SAU.
  • 4 weeks later...
  • 1 month later...
hey, im keen for the rear shocks, what are they like?
Hey Judd, Presuming the carpets will fit R32 GTR we'll prob take em.
wanted some from t88onboard on here, but he doesnt seem to reply.
Really want for this weekend - so a quick reply would be appreciated.
thanks
[email protected]
Michael
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
