  • Replies 148
Posted Images
Here are some more pix.
The gudgeon pins were all siezed to the rods instead of being floating like they are supposed to be. The failure was not due to any fault in the piston but the stupidity of the engine builder.
Edited by Blitz
Sorry to hear about your woes Matt, but for legal reasons we cant allow businesses to be slandered on this forum, justified or not
Edited by Blitz
I'm no expert engine builder but I have seen gudgeon pins walk out and run on the cylinder walls . Generally the locating circlip (sp ?) has failed and no longer locates the gudgeon pin . I'm told Spiral locks never fail if fitted properly , may be worth a look .
Cheers A .
The spiral locks didn't cause the failure. The gudgeon pin as I said was not floating on the rod causing the spiral locks be to simply smashed out. I also have 2 bent rods....
the spiral lock on number six was a bee's arse from coming all the way out also.
The gudgeon pin should fit into rod with only palm force and slide along the length....these are all rock soild.
Edited by BOOSTD
Ive built quite a few engines over the years and have found that i usually have to hone at least one conrod per build as they have been to tight.The last motor i recieved for rebuilding was a freshly built sr20 with hks pistons that started making death rattle noises.I thought for sure i would find at least one tight little end but ended up being tight piston to bore clearance (1 thou).Made a mess of one piston and bore and the others looked like they were ready to grab and tear.Had a lot of wear on the skirts for a motor that had only done a few hours work.
That's a really odd failure. The small end clearance is only .0002-4" which is really just enough for the pin to push through with light thumb pressure. How long did the engine run before this happened?
It's strange for there to be enough side load on the pin to force the side of the piston out, even with the pins seized in the rod.
Any decent engine shop will warranty their work though, have you spoken to the shop yet?
The engine lasted 300km.
Side load was magnified by my rods being bent from the siezed pin.
The shop sent me packing with only an oil leak warrenty after trying to over charge me. The response was, "you didn't get a written quote so I can charge what I like" I am letting the authorities assist me in the right process for compensation.
Thats bullshit! Best of luck with it all Matt - hopefully the car is sorted soon.
That warranty is bs.
Ive been through consumer affairs before, and it states if you dont get what you pay for, you are entitled to a refund...
ie if you pay $200 for a watch, you expect it to last / work properly...
Ring consumer affairs, and tell em your motor lasted 300km's..you will have a case for a refund, as no one expects a motor to die after that short of a time.
Good luck :P
this picture does not do the damage justice :rolleyes::(:unsure: the bit you cant see is the depth of the score, i was quite disturbed when i saw it.... but, we will sort you out and get you back on the road ASAP!!!!!
http://www.skylinesaustralia.com/forums/in...pe=post&id=1538
hopefully these pistons serve me well.
the new motor should be going in about 3 weeks. i will let you know how it all goes
Just a tip, have a very close look during assembly at the clearance between the oil squirter and the side of the piston, if you move the piston from front to rear in the bore you will see they run very close. We modify the locating lug on the squirter slightly to move the squirter away from the piston.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
