Hey guys,
I need my timing belt changed. I've bought one and i have it's gettin put in on friday for a bit more than i'd like. So if anyone is willing enough to spend some of their time and know what they're doin, i'll give ya 2 free slabs or cash equivalent :D
https://www.sau.com.au/forums/topic/68704-2-free-slabs-anyone/
Doing a timing belt on a 33 is no easy task, especially without the right tools. Ring around and get it done at a w/shop.
My Mechanic:
EAS performance
Contact : Vic
Tel: 9330 2001
Add: 11 Victory Str/Rd, Airport West (near Tullamarine)
I have been going to Vic for the last 3 years without any drama. A few of my mates also use him and have found his work to be of a high standard.
timing belt is an easy job....the only special tool needed is a balancer puller and its about $20...and there ARE certain shops i wouldnt be taking it to....for fear of been lied to and torn a new arse in the bill department...what area are you in?
I'm in the southeastern suburbs....i think i'll take it to this workshop i know of. He seems to know a fair bit about imports....anyway just for the timing belt he has quoted me a minimum of $280 to change, me providing the timing belt. He said it could go up to around 310 if something was rusted and hard to get off or something, meh i dont know, but he seemed to know what he was talkin bout
Cheers dudes,
SImon
Good luck if you can get the bolt undone. I used a 2 metre poll a hammer and some rachet straps to hold the balancer whilst it was in gear and the brakes were on and it was done up bloody tight. Read the manual to see what its done up to 270ft pounds or something like that.
You lot are limp. Ever see a real mechanic at work? We use a half inch breaker bar, an extension pipe and wedge it against the chassis rail, then use the starter motor :D I do have a tool I made to make it easier if that don't work though.
I have had bolts at 1000 foot pounds on my old Mack truck that took some sweat out of me. 270 is like lifting a slab of beer. It's all in the way you hold your tongue :D
Sorry but I'm not doing any work for anyone at the moment. Too busy getting ready to sell the house so I can "punch out" of Victoria for good. (caught up with some jet jockey mates during the airshow so adopting new cool additions to my vocab, still concerned at a helo pilot using that one though...talk about mental images of slice and dice)
While it is apart I recommend the idler and tensioner pulleys be changed. Do a search for the thread that details it all.
Why not give the boys at chasers a call>? They just moved shop to near footscray (end of dynon road next to toyota dealership) so its probably a bit out of the way, but they do good work and its all guaranteed.
Call Benny - 0433 184 724. He's a bit of a smart arse but he does good work.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
