  • Replies 172
Still out there somewhere. Usually about 5 days before they land I get a notice of arrival. I still haven't got it yet.. If I don't get any confirmation before the 10th I will look deeper into it. Such as ask the shipping company how things are going?
How good are these kits compared to all the others that i see around the traps? Im after a good quality kit that i can bolt onto my R32 GTS-t with minimal fuss and modifications but know that it will do the job and not last few a few months then give me grief.
can you match the prices offered by the guys on Nissan Silvia? The same spec ones from the same manufacturers are being sold for $180 and $150 by two different traders.
These prices are for the intercoolers. I believe in healthy competition, but what's going on in ns.com, I think it's too bizarre.
Well here is one statement he on the add.
Pressure Drop: 20PSI - 17PSI .. What the? nice pressure drop over the cooler.
same manufacturer I doubt it. What gives you that idea?
There is cheap and there is too cheap! I have cheap but I don't sell parts that will fall apart in 3 months. I would watch out buying coolers at $150... Have you read the stories about the coolers whistling. Those really cheap cooler may well be the ones and the manufacturers are trying to get rid of their stock. Maybe, I'm just speculating why they are so cheap. Or maybe they are defects.
But so far I have had 100% happiness from my customers, no faults found, no whistles and no returns. Sorry, I can't match their prices impossible!! But my assumption would be my coolers are of better quality from my feedbacks so far.
Maybe some of the guys who have received the blue kits and coolers can give some feedback.  :cheers:
Yeah that would be good to hear from others that have them???
would be good to know if the horns and temprature sensor need to be relocated and where they put them, also how the top plumbing fits between the top radiator hose and fan (R32 related).
cheers
Okay guys.. .Here's what you've been waiting for.. feedback
Started the install on a mates gti-r on Saturday and still going.
The piping is very good quality and no complaints there, all the associated brackets are in the right places and everything was provided. I was dissapointed with the clamps which kept on falling apart and were out of shape, also the piping for the gti-r went too close to the Pod (about 100mm too close) and now the pod has to be changed and/or relocated. Would of been worse with stock air box.
Anywayz.. overall the kit is good, the kit fits great, great quality piping just needs to improve on the quality of the clamps. Apart from that great kit :) (would be good if the piping didnt go directly where the air box goes though.
Thanks mate.
Greg
I have just fitted the intercooler to my car and all looks great. I have one questions thou there is a red rubber line with a T piece and I have no idea where it goes can anyone tell me as I'm no mechanic and one line I pulled off the intercooler ???
thanks
SirSkyline
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
