  • Replies 172
Just fitted the intercooler piping from Raf yesterday. Took me two days cos i didn't have the correct tools and had to source for them. Overall, the piping quality is good but u have to cut away a fair bit of the fan in order for the top pipe to go across the engine without touching the blades. Kind of worried now cos i have consulted a few mechanics and they have all discouraged cutting of fan blades.
Also, the clamps given are useless. No way u could fit them in.....Spend lots of time trying to get them fitted but ended up using the old clamps for my original piping.
Also, i couldn't bolt the piece of metal sticking out to the engine to hold the front pipe in place because i would have to cut even more of the fan blades. so i ended up using cable ties in the meantime before maybe getting someone to make a bracket for me.
By the way i fitted them on a S1 R33 with some help from a guy on the forum.
Babylon....Gimme your email and i will send u the instructions.....Just got the kit fitted on my car yesterday. Seriously the instructions are not much of a help.
Damm i wanted to buy one and do it myself
Is it hard? coz i have no phuken clue what i am doing?
I rang around and the cheapest i found for a pro installing one was $450
[email protected]
Thanks man,
i wouldnt say its hard, id just say it takes some people more time than others. ill post as much info as i can when i get mine.
any word on the arival or is it still sumtime b4 the 6th??
Babylon....Where are u located??? If u are from brisbane try option1garage. Got a quote for $250 to install the kit and trim the front bar to fit before i decided to do it myself. But end up with Jay helping me out most of the time.
ahh shat im from syd dude but thanks anyway :)
That sounds like a nightmare!!!
I have personally installed 3 of these kits on R33's and apart from the clamps all were perfect fits.
With the right tools I am capable of installing them in 2-3 hours depending on how lazy i am.
It is very easy to install these kits.
Cutting the fan blades is a must on even the origional Hybrid Kits which i have also installed and purchased.
Minimal effect and heat difference is noticed.
Consider that the intake temperature is 20 degree's less. :)
So when will they be posted raf?
this might be a stupid question but what did u use to cut the fan blades? can u do it while they are still on the car? anything else you have to cut?
I will ring up tomorrow to try an get a precise date. But I have given customs the documents, the money etc I'm just waiting on th warfies to move there arse.
how to cut: try a coping saw
I always used a grinder to cut the fan blades.
As the blade cuts the plastic the heat leaves the blades nice and smooth and even by melting the plastic off.
update: I talked to customs today they said the ship landed in sydney and will frieght the kits up on the weekend. Monday tuesday I should get the kits. So the very next day I will post them off :)
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
