Dude, there's a sticky in this VERY FORUM telling you how to attach images to your posts ;):)
Here's the link: http://www.skylinesaustralia.com/forums/sh...ead.php?t=47677
Dayuum... has anyone tried this on an r33 yet? it's right under the inlet manifold! basically need to take the whole inlet off to even see it! this will be a bastage of a job...
Hence my tut and pics to show where it is. It took me forever to work out what it was based on people's description! haha
I dont think you need to take the whole inlet manifold off. I was trying to get to mine coz i have a high idle problem. If you take the oil filter off it will give you a bit more room.
I just did an oil and filter change so the air regulator is going to have to wait
yeah it's actually in a different spot again... the biggest thing for me was knowing what the damn thing looked like! but yeah descriptions alone just dont cut it! below that WHAT, exactly? :P
good work mate
Inasnt you're right removing the oil filter will free up a bit more room, still think it'll be a caaaaan't all the same. I'm in the same boat as you, just did the oil change. it's just a right piss off! the other day my damn car stalled because of it... and I hate hearing that pinging when it pulls itself back up off 100rpm! think i'm just gonna have to skin some knuckles...
  • 2 months later...
  • 1 year later...
This was an absolute pain in the ass to do, had to open up the air reg while inside the car coz the harness would just not come out. But I am so happy after checking AFM, throttle body, TPS, cleaning AAC this finally semi-fixed my idle.
It has however mostly fixed my idle, I'd like to know whether inside of it the opening is meant to be over the hole at all. In the picture posted it looks like there is still a slight gap(about 1mm), and that is the same with mine, however I would have thought it should be fully closed. The idle has dropped down now(but now its almost stalling coz it drops well under 500 after reving then flicks back up), but I wanna know whether i will need to buy another air regulator to adjust it all properly.
btw I couldn't find a spring to buy that was small enough anyway.
Cheers,
Adrian
  • 9 months later...
I will be trying this tonight...Does anyone have any pics specific for R33?
I had a look last night to see if I could find it based on this thread, with no luck.
I might take the plenum off to make things easier.
  • 2 years later...
I took mine out and gave it a clean however I noticed that the spring was not holding the bimetallic plate on fully, allowing air to escape on idle (causing idle to stay around 1500-2000 depending on temp)
I got a quote from Nissan, $276.95 for a new valve. I will give this a go and report back. Hopefully the idle will drop back down to normal.
  • 8 months later...
For an R32 RB20 you don't need to remove half the stuff listed. I just pulled off one side of the 2 small vacuum lines and the larger lines with the T-piece. The only tricky bit is working around the loom which runs over the top over the unit. Oh and dropping the bolts down into the manifold :).
Hence me saying...
"2) Have a look, and work out if you can get to it as is. I couldn’t; so I chose to remove the following, you can skip ahead if you think you can get to it without removing them."
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
