ey mate, im heading off now to calder not to enter my car, but to watch my bro.
My bro has a red and white Yamaha R1, with chrome frame he will b their with another R1 a blue one. Should b good. Bit to hot at the moment. Mite c u their.
Paradizzle
I saw your runsa bobbygill, awesome car mate.
My Bro ran 11.032 on his R1, did u see it the red and white one with chromed up chassis? Oh and did you see the merc spin out just before crossing the line?
Paradizzle
thanks paradizzle, my car wasnt running the way i wanted it to run yesterday, maybe better next time. i remember ur bro's bike, man thats a beast of a bike, and that merc was a beast as well hey. what about during that burnout competition, that guy on the motor bike, he nearly slammed into people, he was thrown out straight away from calder park.
lol yer the guy on the bike was funny as, first thing he did was try to do a burnout then fell straight off. i was in the pits bit, i was standing right near when he almost hit that security guard. he almost hit the tractor on the track when he was doing a mono all the way down, wat a nut.
Big turn out, i didnt think their would have been that many ppl caus i thought it was going to be 2 hot. wasnt the best of weather would hav ben better if it was cooler.
im about to buy a line, seeing yours makes me want to get one asap, nothing like the speed of turbo! damn.
paradizzle.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
