SKYLINES AUSTRALIA - NSW 2nd Annual Show and Shine 17th July 2005
hihi~~~
i just wanna know how to make a entrance?
do i need to pay first , or can i just turn up wif my car then pay at the gate?
thanx
sign the form and send it in then DD the money to the nominated account on the form
  • Replies 165
Posted Images
How far is this place Tumbi Umbi from Sutherland??  I might come if it won't cost me more then 100$ fuel both ways..
one or two hrs.. come come come :(
meet up somewhere and we will all go :P check
http://www.skylinesaustralia.com/forums/sh...ead.php?t=79565
Oh thanx!~~
sori but where do i get the form , and how do u know if i m in?
Entry form is at the bottom of my sig! :D:(
Send the entry form in, and that's all you have to do! (Besides show up on the day that is! ;))
You can, The main car park at mingara will obviously still be open for there members and guests, so just park in there and wonder round and say hello.
Quick question. Just filling out my form. Do we pre-pay for lanyards or order them then pay on the day?
Also is there any chance of having all the cefiros together? :rofl:
Turn up together get parked together is the rule although if we can get around it for you we will.
No worries Bob thanks for the reply.
I'm just about to send my form in now... Where it says "Please supply ... lanyards at $5 a peice on the day" does that mean I'm meant to include the lanyard cost in the enclosed monies or we just order them on the form and pay cash on the day for the lanyards?
Id like to know this too... As im not sure if I shouod pay $15 DD or $10 DD.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
