Yeah this was me...
It was pretty bad, the 34 has seen better days. Lost control of the car at only about 50 on the round about.. Im still trying to figure out what happend.. if there was something like oil on the road or what. got mild concusion from the accident hitting my head on the b-pillar but Im all ok.
The 34 was smashed up pretty bad, both rims are bowed. the front suspension arms are all gone. the engine is good and and cooler.. the only thing that burst was the water resovior for the window washers. the rear right fender as seen better days.. The worst damange is the rear where the impact cut the fuel lines and all other lines back there alot of eletrical for some reason.. dont know why there was so much electircal wiring near the fuel lines on this car.. but they were all cut.. the fuel tank wasnt ruptured at all. and the exhaust system is fine.. with the the car on a hoist that night.. the steel undear the car is ripped.. actually torn into and I can see into parts of my boot from underneat. the estimated repair at the moment is around 15g and thats with second hand parts..
Just want to say there was a white R33 that stopped to help and a green 200sx. Thanks for stopping guys was really apprecaited..
Hey bro.. I will sms you my number..
I need help with parts mostly.. a rear halfcut is probably going to be needed.. so if you know anywhere to source parts that would be great man..
Cool cool... you at work today?
Ill try all the places I get my parts from and see how much they want for a rear cut, I doubt its going to be cheap though :) Will let you know
Thanks all for the well wishes.
Leech the car only had third party on it at that present time the switch over back to comp was not until 2 weeks.
No not at work today amaru.. The car is at Daves shop if you want to check it out.
I still dont understand what happend as I was only going at 50-60kms.. the car behind me said there were sparks coming from the rear rims.. yet both rear tires were fine.. so im at a loss.. there wasnt enough body roll for the rims to scrap..
Im not saying im the best driver in the world.. but Im used to throwing that car around alot and it felt completly different when this happned.. when it snaped back the lift side was thrown so hard it lifted the car off the ground for a moment and slammed into the railing.
the police at the scene stated that was not going very fast well withing the limit and they couldnt find the cause. I was hit with neg driver $150 fine.. not that they money makes any difference to the cost of repairing the car...
oh well live and let learn I guess..
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
