Hi Everyone,
Got pulled over by cops today .. I wasn't speeding.
Apparently my car is under 100mm (which is the required legal height) but only when I am in the car .. yah Im 90kg but still.
Also he mentioned that my POD Filters dont meet ADR Compliance Rules or something like that.
So just wondering what I need to do as I have stock VSPEC Suspension. Can I raise it a few mm? Is that a small or big job?
Also with the Pod Filters, Do I need a Box covering it? Will that make it legal?
Any info will be great thanks.
PS: He let me off with a warning but I like to comply with the rules where I can.
https://www.sau.com.au/forums/topic/70842-quick-question-on-road-worthy/
Get it engineered - as far as I know the 100mm is not measured with anyone in the car.
As far as I'm aware technically any mod you do on your car needs engineering, including the air filter. A box won't make it legal-er it will just hide it.
I have my non-oiled pod engineered with no box - so the "so long as it's in a box it's legal" is an old wives tale, atleast in NSW.
Good luck.
under 100mm with stock vspec suspension? I was under the impression that an R33 GTR Vspec had 135mm ground clearance, and a non vspec had 145mm ground clearance.
have you measured it yourself? I can't imagine your car would have droped 30-40mm over the years?
I live in NSW, but bcoz u live in Vic, maybe u can check this out: http://www.vicroads.vic.gov.au/vrne/vrnav....A256ED10015E72B ,and u can also do more search about "Vehicle Standards Information"s there on the vicroads website. As far as I know for the pod filters, lot of people've already got defected from pod filters.., and like someonestolecc, I don't think covering the box will make it legal. So after all, engineer and engineer certification seems to be the best way.. Gud luck with your job.. :D
Good luck.
so how much would it cost to get a pod filter engineered ? can the dealer u brought the car off engineer it for u ? (assuming they're a raw compliance workshop)
You probably find that he has a bigger exhaust and it hangs down .
The 100 mm minimum hight is when fully loaded !!!
Pod filters do not need to be boxed.
Vic EPA laws state that you are only permitted one intake modification. (explained below)
If you have an aftermarket intercooler, you must run the standard air box to comply with EPA laws.
Thanks for the info Sky031.
So from what you stated mine should be okay as my intercooler is stock?
R31Nismoid: Yah it drops 2mm when I am in the car. It is stock VSpec Suspension.
It can be argued but I rather know that I have everything correct and complying with whatever standards. But the police officer was being a bit picky as I am sure there are far worst cars than mine :)
if you have the compliance cert, and the engineers, they you wont have a problem.
i was in court over a similar thing. Car was designed a certain way and complied, then an officer deemed it not too be legal, when in fact it was due to the vehicle's design :)
I thought it was 100mm unladen? If not, what is deemed as fully laden, 4 passengers plus luggage? I am sure when mine was attempting compliance it was 100mm unladen though the compliance guy told me and he was to the letter.
Brandon: My air pods are not boxed and not a problem as they are the single intake mod as mentioned by Karina.
From my numerous encounters with Prahran Police - they aren't always aware a GTR has a FMIC as standard equipment, and so pick it up as 2x mods - as a GTSt would be, hence the confusion.
Filter doesn't need to be boxed.
However, in the interest of keeping heat away from the intake, it makes sense to at least have some sort of division between the pod and the rest of the motor.
(No law that says pod filters need to be boxed)
James I will keep that in mind thanks.
How does one get a Engineers Cert?
And Does anyone have the link handy where I can print out these rules .. going to study these rules further.
Cheers
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
