Guest MFX_R33
I hit about 210 in my car when it only had about 170rwkw, and it was still pulling hard. I think it would have easily hit around 230-240. I also got taken for a drive in a Zeni Tani worked GTSt with 255 rwkw. With 4 of us in the car we hit 250 on the Nismo speedo before we had to back off for a corner. It was pulling out so easily, it would have gotten at least 270 (plus it had an 8000 redline, so who knows?).
Jeff.
While sort of on the topic of top speeds....
Whats the longest u guys actually drive on the speed limiter for ?
I think im doing about 4,500rpm @ 190km/h @ 7psi in 5th Gear and its pulling as hard as 2nd gear would.
I've driven mine about 5km before backing off, but now that i have done an oil change (after exactly 10,000km on the old oil) i'm alittle more confident that it can take it easier.
The ride is dead smooth and you can -literally- take your hands of the wheel and just sit back and relax. (while watching the fuel level drop like a $2 hooker on a Saturday night).
Originally posted by predator666
I'd say for a box on wheels, an R31 would have massive drag!
Yeah, who knows about speedo error but generally i think mine was on target because i did a test once on the hume on that measure speed points and it was bang on at 110km/hr like the speedo was saying.
R31 - "box on wheels" = plenty of drag = unlikely to reach 220+km/h.
A speedo might "seem" accurate tested via a few road signs on the side of the f/way. It might also be close @ 100-110km/h but that doesn't mean it's still accurate @ 180+km/h. Most speedos have non-linear error.
I think you'd be fairly surprised to see just how inaccurate your car speedo was when tested via a known calibrated measuring device. Especially @ high speeds.
Talking of high speed I just heard from a good source that a recent magazine speed test had a production CSV Commodore register 286km/h on a speed gun!
how do u guys get to that speed?? i mean when im going above 140-160 the car starts to feel very drifty ... as if the hicas is acting up ... do u all have ur hicas on?? i'm going to get my steering looked at soon but it feels as if its sliding on ice ... too scary for me :P
I feel safer sitting in 5th @ 190km/h with no traffic around on the motorway then i do when driving in 2nd doing 50 in peak hour traffic coming to work.
no movement
the only noises are the wind resistance
engine purring at about 5,000rpm
brrrrrrrrrrrmmmmmm
But the only caveat is you **** up you die.. that don't happen at 50km/hr but a drive at that speed stresses me more I agree in terms of a stupid accident, etc. There are so many people that just have never ventured onto the highway, don't drive appropriately for the conditions in peak hour, blah, blah.
I've got a stupid thing where if I'm driving the speed limit I lose attention very quickly and my mind wanders because i'm not thinking about the driving then. My mind just turns off, its scary. If I'm going fast, I'm thinking every step along the way... Its totally different. Its something about endorphins and things, i dunno..weird
Scary...any car can do that speed comfortably... even my ancient Sigma did that. The only car that made me feel unsafe was a daihatsu which really would not feel safe about 100km! I'd get your steering, suspension, control arms, etc looked at professionally. If something goes wrong at that speed (something snaps) well you can imagine..you will be flying sideways off the road and not in a fun way
Yeah, when you're going fast, your so busy watching for cops that you can't fall asleep!:bahaha:
  • 16 years later...
Memories of my old R33 GTST boat on a runway in Goulburn for the SAU nationals.
I tried to find the results, times and speed, but to no avail.
If I recall I was only a couple of kmph short of overall top speed, some shops R34, blue one?? beat me, it was the one that took the 4WD trophies anyway.
I recall calling shenanigans on their speed IIRC.
Their fasted run was a run they never did.
Allegedly
9 minutes ago, admS15 said:
@mlr Kingmlr long live the king
LOL
That car was a love hate relationship.
Spent more time broken than running if I recall.
It triggered me and made my eye twitch when I saw it at the GTR festival at WSID this year.
It did go good in a straight line, but not so good around corners, but that was more to do with the low grade nut behind the wheel.
3 hours ago, WR33KD said:
Couple weekends ago at the track I got 230kph in 4th gear, needed a longer straight to click 5th
What rev limit, gearbox and diff ratio? Whats 5th top speed?
Ive got 214 max in 4th at 8000 rpm with a ppg rb25 box (still 1:1) 4th and 4.11 diff... have been looking into diff ratios
Diff is a 4.081 and gearbox is a 26 dogbox and have never needed to use 5th as there isn’t a track here. Rev would have been up around the 8500rpm as rev limit is set to 8900rpm
  • Like 1
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
